U0306
Old Nov 23, 2021 | 08:09 AM
LouWap22's Avatar
LouWap22
U0306
Good morning Fellas! So last night I get a call from one of my crew members and says that our 6.0 kept shutting off on him. He had it running for 5 hrs at idle as they were drilling under ground. He got it running but could not go faster than 50mph on the highway. Scanned it this morning and the only code I have is U0306. Test drove and only goes about 50mph with a load in the rear. I cant seem to find a diagnostic check list for that code. It wont even come out on alldata. My battery voltage is good. Ficm is showing 48V ,12 ,12. I replaced this ficm back in may so its under warranty. Could My PCM be messed up?
I searched on the forum and saw a thread back and July but there was no diagnostic steps or a solution or fix. Sorry if this is another repeat!
Old Nov 23, 2021 | 08:32 AM
Brotherbillstruck's Avatar
Brotherbillstruck
From what I found that is a common code when replacing the FICM. Supposedly not an issue. It may have been there since the swap. Trouble light on? What are you scanning with?
Old Nov 23, 2021 | 09:13 AM
LouWap22's Avatar
LouWap22
First time this code popped up. Im using a mac tools Scout scanner. Trouble light is NOT on,
Old Nov 23, 2021 | 09:21 AM
Brotherbillstruck
That looks like a competent scanner. It is baffling that it is running that bad and not setting a code. Were you trailing any smoke?
Old Nov 24, 2021 | 06:27 AM
LouWap22's Avatar
LouWap22
No smoke. I drove it as well and it did the same to me. Was going 70mph and then it started to slow down with the pedal to the floor. HPOP was still in the mid 2000 range. Pulled over and it shut off. Wouldnt start for another 4 mins. I popped the hood, I turned ignition on and noticed my fuel psi gauge on the filter was still saying zero until I cranked it for 3 seconds I saw the gauge rise and it started. So im thinking rail pump issue?
Old Nov 24, 2021 | 07:28 AM
Striderwv's Avatar
Striderwv
How many miles on the hfcm? Can u read FP while driving?
Old Nov 24, 2021 | 07:31 AM
LouWap22's Avatar
LouWap22
No idea how many miles. I dont know if the previous mechanic replaced. I know he loved carquest parts. My fuel psi gauge is on the fuel filter housing so no...Might have to transfer
Old Nov 24, 2021 | 08:01 AM
Striderwv's Avatar
Striderwv
IIRC, Jack had a poll on hfcm failures. Somewhere around 180k??? I recently pulled my cover and remove the goo. May b worth a look, especially if you have the fuel heater. Great thread below on how to put the screws/bolts back in.
Defiently transfer.
Old Nov 24, 2021 | 09:30 AM
LouWap22's Avatar
LouWap22
ill get into that shortly. I will keep you updated. Possibly Monday before I touch this
Old Nov 24, 2021 | 02:04 PM
LindenBruce's Avatar
LindenBruce
The U0306 just means the programming in the FICM doesn't match what the PCM is looking for. Do you have a tune in the FICM? If so, that's what is throwing that code. B.
Old Nov 24, 2021 | 02:27 PM
LouWap22's Avatar
LouWap22
All stock. No tuner, no mods
desertt5
Jan 10, 2011 02:25 PM
rtazz17
Dec 31, 2009 05:06 PM
Skreamr
Sep 20, 2008 12:17 PM
primerider
1997 - 2003 F150
Apr 1, 2006 08:50 AM
2000 F-150
1997 - 2003 F150
Apr 20, 2005 08:15 AM
