Tips on removing starter
Old Nov 22, 2021 | 04:10 PM
abe's Avatar
abe
I'm putting my 55 away in storage for the winter. I am getting the starter rebuilt. I've removed the starter on my 54 probably 3 times but it's been a while. So I need a quick refresher so I can get it off quickly since I won't be at home.
Any quick tips? 3 bolts, correct? Of course remove the cables. Easier working from the top or underneath the truck? Anything else? Thanks.
Old Nov 23, 2021 | 06:06 AM
rico56's Avatar
rico56
Hi Abe,
you better work from underneath the truck, otherwise the exhaust system blocks the way. If you have stock exhaust (I guess you do) the starter should come free easily downward. Since I have the rams horn I had to remove the first part of the pipe to get the starter out. I prefer to disconnect the battery at first, then removing the cables from the starter and in the last step the bolts (2 or 3 depending what starter you have). Please take care with the pinion when removing or installing the starter! Thats the most vulnerable part of the starter.
Old Nov 23, 2021 | 09:36 AM
avf100's Avatar
avf100
Originally Posted by rico56
Hi Abe,
I prefer to disconnect the battery at first.
That takes all the excitement out of a boring job
Old Nov 23, 2021 | 01:25 PM
rico56's Avatar
rico56
OK, the only time I don’t do this is New Years Eve
Old Nov 23, 2021 | 10:19 PM
thrifty's Avatar
thrifty
I put a stud on the top bolt. I leave the stud in there for next time. That way putting it back on makes it easier. I don't have a lift so I am on my back fighting all the elements.
For transmissions I will cut the heads off 2 bolts, cut a slot on top of each one and you take one out a time and the alignment is so much easier.
I do the same for head bolts, it takes all the fighting out of it. Ok I'll stop
Old Nov 24, 2021 | 10:09 PM
mOROTBREATH's Avatar
mOROTBREATH
I thought you're supposed to let the starter dangle from the wires for at least 30 minutes before disconnecting?
Old Apr 8, 2023 | 07:47 PM
Mr. Rogers's Avatar
Mr. Rogers
Long extension
I have long extension I can reach top bolt from the front of the engine.
mr56
1947 and Older Ford Trucks
Jan 19, 2015 04:50 PM
senorswanky
Apr 13, 2009 07:06 PM
etnies13
Jul 14, 2006 08:43 AM
Rough52
May 12, 2006 01:13 AM
theCroch
Nov 7, 2003 09:25 PM
