New Starter
Old Apr 13, 2009 | 01:24 PM
senorswanky's Avatar
senorswanky
New Starter
Is it fair to pay $150 to $200 to have a new starter installed in an F250 460 Camper Special? I'm not that great mechanically, so I think I'm going to have to have someone else do this for me. Thanks for any help.
Jeff
Old Apr 13, 2009 | 01:25 PM
senorswanky
That's parts and labor.
Old Apr 13, 2009 | 02:18 PM
427 fordman's Avatar
427 fordman
If you unhook the battery, follow the cable down to the starter on the pass. side, unhook it from the starter, remove 2 starter bolts holding it in and you have it. If you really wanted to you could do it. It is very simple. If you absolutely don't think you can it should only take a mechanic about 30 minutes(if that). Find out how much a starter is and that will tell you how much he's charging you.
Old Apr 13, 2009 | 04:17 PM
IZZYAZ's Avatar
IZZYAZ
I have never put a starter in until this last weekend. Piece of cake. On the 390 there are 3 bolts, top one is a little difficult, but nothing horrible. Total time for me to just install the starter was about 30 minutes. Now you have to take into consideration it's a clean engine, no exhaust just headers.
If you can turn a wrench there should be no reason you can't replace a starter on one of these old trucks. In my opinion it's almost harder replacing the oil filter on the 390 then it is to replace the starter.
Old Apr 13, 2009 | 04:53 PM
fmc400's Avatar
fmc400
MSEE
While I agree with you all on how easy it is to replace the starter, his question was whether or not $150-$200 is too much and I think it is, assuming a remanufactured starter is used, which I don't recommend.
Old Apr 13, 2009 | 05:42 PM
highboy1975's Avatar
highboy1975
i think its too much as well. a starter for these motors is cheap....i think it was under 50$ for the starter on my 390. if you can change a tire, you can change a starter. these are SUPER easy.
Old Apr 13, 2009 | 05:54 PM
senorswanky
Thanks a lot everyone, I think I'll make an attempt.
Old Apr 13, 2009 | 06:05 PM
460me's Avatar
460me
Just remenber to take the postive cable of the battery.Very simple job,just take your time and don,t strip the bolts while tighten it back down.
Old Apr 13, 2009 | 07:06 PM
fmc400's Avatar
fmc400
MSEE
Don't use $50 remanufactured starters people. Enough of those, and you're in for a new flywheel.
Originally Posted by 460me
Just remember to take the postive cable of the battery.
Always remove the negative cable first. If you remove the positive cable first, your wrench can short on the grounded fenderwell and spark, which can ignite the fumes around the battery, and kaboom. Negative comes off first, and goes back on last.
