Sponsored by: Real Truck
Another P0480 question
Old Nov 18, 2021 | 05:41 PM
EMD_DRIVER's Avatar
EMD_DRIVER
The search function didn't do me much good for this one.
Got the code and found the fan not working. What is the fan controller location on the 2014 Super Duty? I'd like to see if it's the clutch, or the controller that's failed.
Old Nov 19, 2021 | 10:00 AM
Fleetsuper's Avatar
Fleetsuper
The fan is in the center of the dash, it requires removing the dash to replace it. Not sure where the fan controller is located, but it seems the dash has to come out to do just about anything on a climate controlled heat and A/C system.
Old Nov 19, 2021 | 11:43 AM
Mike1's Avatar
Mike1
I'd check the ECT sensor first. https://repairpal.com/obd-ii-code-p0480
Old Nov 19, 2021 | 03:12 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Originally Posted by Fleetsuper;[url=tel:20159537
20159537[/url]]The fan is in the center of the dash, it requires removing the dash to replace it. Not sure where the fan controller is located, but it seems the dash has to come out to do just about anything on a climate controlled heat and A/C system.
Guess I didn't specify.. This code is for the cooling fan control circuit. I did check the turning resistance of the fan and it doesn't have near the resistance as others that I tried. I'm figuring the clutch is toast.
96_F250_Deezal
Jan 19, 2013 10:13 AM
catfish101
Nov 23, 2006 11:26 AM
eclectro
Jun 15, 2006 10:51 PM
95bogginbronco
Jan 30, 2006 08:52 PM
fatherdoug
Aug 8, 2005 01:40 PM
