Sponsored by: Real Truck
2016 power issue
Old Nov 19, 2021 | 12:19 PM
BrrpaDrrp's Avatar
BrrpaDrrp
2016 power issue
Looking for some help. 2016 f350 was driven around 60 miles after being filled with gas. Truck came in miraculously still running. Dropped the tank and cleaned. Ran about 16 gals of clean diesel through the system and into a drop pan. Hooked everything back up. changed the fuel filters. Installed a contamination kit (HPFP, Fuel lines, Injectors, Fuel rails) Replaced the LPFP and fuel cooler. Went ahead and did a EGR and DPF delete. Tuned the truck with an H&S Mini maxx. No codes present. This truck will rip outta first gear, hit second and straight face plant. No power, no quick acceleration, forget going up a hill. Tried removing and re downloading the tune mulitple times with no change. Any ideas on what is wrong?
Old Nov 19, 2021 | 03:39 PM
wp6529's Avatar
wp6529
Originally Posted by BrrpaDrrp
... Any ideas on what is wrong?
Never, ever do a repair and then go one to perform modifications before fully testing the repair. You introduced a whole lot of variables with those modifications which will make it difficult to isolate whether the problem was in the repair or in the modifications.
gibbycrew
Feb 15, 2015 11:32 PM
JPSLLC
Oct 24, 2013 06:56 AM
empireskidloader
Feb 26, 2011 05:58 PM
Smokey1
Feb 14, 2010 11:05 AM
boeingoing
Sep 3, 2009 03:14 PM
