Hi,
I owna 1995 Bronco with a 5.0. and the super cooling/towing package. I know that I have the severe duty fan clutch and the blades are pitched to allow the clutch to engage and disengage. My question is that when the fan is rotating are the blades supposed to be moving back and forth alot almost as if they are all bent? There is no play in the clutch and the blades look fine. Any thoughts would be great. thanks guys
In my experience, a badly out of balance fan will lead to premature water pump failure. I went through 2 water pumps on my GTO before I figured that one out.
