Headlight Upgrade
Old Nov 15, 2021 | 11:27 AM
Ronnie Shierling's Avatar
Ronnie Shierling
Headlight Upgrade
Need to replace my headlights, and have been searching for the right ones. I think I have found them along with the bulbs but I wanted to check with the resources here as my local AutoZone and oreilly's are not as knowledgable or helpful.
Headlight Headlight
Bulb Bulb
Retaining Clip Retaining Clip
Old Nov 15, 2021 | 11:53 AM
96firephoenix's Avatar
96firephoenix
those do look like good headlight housings, but I have had very bad long-term experiences with aftermarket headlight housings compared to OEM, as far as teh reflector peeling, and the lens fading. I even had one that was almost opaque and all of the reflective coating was dust in the bottom of the housing.
So far as the LED bulbs go, I did not have good experiences with the LED lights in the stock housings. I would suggest the upgraded wiring and a good set of bulbs (i.e. sylvania silverstar) first.
https://www.ford-trucks.com/forums/1...l#post19667604
Old Nov 15, 2021 | 12:13 PM
carbon coupe's Avatar
carbon coupe
I'll second this. I put OEM clear lenses back on mine, following aftermarket clear lenses that decayed. I also added the powered harnesses and noticed a huge difference. Very happy.
Still toying with the idea of putting the '05 OEM housings on it.
Old Nov 15, 2021 | 12:23 PM
Antonm's Avatar
Antonm
Can you elaborate on the "powered harnesses", I'm not familiar with those. Thanks
Old Nov 15, 2021 | 12:25 PM
96firephoenix
For what it's worth, the "clear OEM headlight" we are talking about is the 02-04 similar to what you found on amazon
https://www.ebay.com/itm/274949376807
What you want to just toss in the trash is the translucent 99-01 superduty lights like this one:
https://www.ebay.com/itm/234277326185
Old Nov 15, 2021 | 01:01 PM
carbon coupe
Something like this: https://puredieselpower.com/ford/lig...s-Upgrade.html
They are powered directly from the battery to the relay to the lamp, therefore sending full power to the lamp. The voltage drop in the factory harness is what makes for a dim drive.
This reminds me, I have to add these to my pickup.
Grass Lake Ron
Dec 4, 2021 12:36 PM
ttoptom1
2009 - 2014 F150
Mar 6, 2017 10:11 AM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
