Cheap headlight Upgrades
Old Lenses
New Lenses
I went with these bulbs. From my research they were ranked very highly and were specifically designed to have a narrow beam pattern so you don't blind oncoming drivers. They also allow for the bulbs to be rotated once they are installed to create the best beam pattern you can. After adjusting them the light spread follows the same pattern, just much brighter with the LEDs. I also did a test driving past the Excursion at night in my Mustang to makes sure oncoming drivers wouldn't be blinded. The lights didnt blind me at all. They were better than a lot of the newer cars lights in that regard. Glad to see they have made a good amount of improvement in that regard compared to older LED headlight bulbs.
Here is a comparison. The drivers side is the LED bulb. The passenger side it the incandescent that came with the lenses.
This is a comparison of the incandescent bulbs and the LED bulbs on the garage.
Im asking because I had 3 different sets and they were all horrible patterns no matter where they were clocked. I got rid of them all, went back to stock type.
I could watch the beam on the garage door as I turned each bulb and made them as tight as I could.
Don't bet me wrong, when driving down the road I would say that the light spread isn't quite as consistent as my Mustangs but nether was the spread with the incandescent bulbs. There are some spots that the light doesn't hit quite as bright as others. Even with that the visibility is tons better. There are better lights out there, but they are also more expensive. The bulbs ran me $40 for the set. They did require me to trim the back of the locking collar down some. If not I couldn't reach the bulb to adjust it and the power cord caused it to be a very tight fit.
Overall for the time and $$ I am happy with the improved visibility I got.
In the past I tried some LED bulbs in other vehicles and ran into the light scattering issue. They seem to be making some design improvements as time goes on.
sure they scatter a bunch of bright white light around but that's about the best you can say about any LED conversion in the Chicom headlamp assembly that has a reflector designed for a halogen bulb.
at least you went cheap and didn't get suckered by the $300 ones thinking they are the magic you seek.
I guess opinions vary
You just need wire, 1 male headlight socket (or cut your old one off and do direct wire to wire) 2 fuse holders and 2 relays
i really like honda rc-2201 relays, they are cheap and last forever and you can usually get them with the pigtails on them.
pretty much it goes like this:
1. Ground the relay and ground the headlight (pin 86)
2. Power from battery through fuse to relay (pin 30)
3. headlight low or high to trigger relay (pin 85)
4. power to new new headlight socket or old socket to headlight, (pin 87)
been using this for over 15yrs, but i have done it enough times that I don’t need it anymore
http://www.danielsternlighting.com/t...ys/relays.html
Low beams.....
Daniel Stern Lighting Consultancy and Supply
Low beams.....
“When operating voltage drops to 95 percent (12.54v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (11.88v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.22v), bulb output is a paltry 53 percent of normal!”
Check the Daniel stern link, lots of good info. Just by feeding them more power i have increased the output significantly and i Didn’t sacrifice any longevity, it’s a win win. I have done this mod to every vehicle i have ever owned if the headlights were wired through the switch and not factory relays, it makes a huge difference at a very minor cost
A 9007 relay harness and hella 80w/100w bulbs are a great combo. I did this to my F350 and my Ex. The brights are insane!
