Wont Crank
Old Apr 2, 2021 | 07:29 PM
wbetheajr's Avatar
wbetheajr
Wont Crank
Hi everybody, new to the sight and already have questions that some of you might be able to help me with. I have never owned a ford so I am lost. My best friend gave me his 2000 excursion, it has been sitting for about a year. i put a new battery in it and it fired right up and then shut down and will not fire anymore. Can someone help me in the location of the fuel pump relay which I hope thats the problem and not the fuel pump. Im not hearing the fuel pump sing when I turn the switch on, It run good when he parked it summer before last, we took it to the beach many times. It has 211 thousand miles on it and the body is in great shape. I even priced having the V-10 switched out to diesel but the local diesel shop wants 15,000 dollars to change it over if I furnish the motor. Thats to steep for me. The V-10 will work fine.
Old Apr 2, 2021 | 09:06 PM
Dweber85rc's Avatar
Dweber85rc
Check the fuel pump reset switch. Under the dash passenger side by the floorboad.
Old Apr 3, 2021 | 10:11 AM
projectSHO89's Avatar
projectSHO89
Neither the fuel pump relay nor the reset switch will cause a "No crank" condition. Either would cause a "Cranks but does not start" condition. A "No crank" condition means the starter motor does not rotate the crankshaft.
Clarify the symptoms.
Old Apr 3, 2021 | 10:31 AM
alloro's Avatar
alloro
Try using starting fluid, that will confirm if it is or isn't a fuel delivery issue.
Old Apr 3, 2021 | 04:50 PM
wbetheajr's Avatar
wbetheajr
it is turning over but not hitting a lick now
Old Apr 3, 2021 | 06:43 PM
projectSHO89
Whatever the hell that means. I gave you the proper terminology to use.
Old Apr 7, 2021 | 07:00 PM
rockhounds4x4's Avatar
rockhounds4x4
so it will crank, but is not trying to start? Check you fuel reset as stated above
Old Apr 7, 2021 | 11:44 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
well see now the rickety jicket twirls a spell but she taint got no fire in er belly see, i figure sheda sputter bettr with some dat der juice in der, mustta be dem wers i seen dat rabbit chewin on fer a bit cause my radier dont play no mo neither.
Old Nov 15, 2021 | 03:17 PM
wbetheajr's Avatar
wbetheajr
It was a bad fuel pump
camper357
Mar 25, 2019 07:23 PM
FordFanatic99
Modular V10 (6.8l)
Dec 29, 2015 09:16 PM
Khannink
Dec 3, 2013 08:04 PM
Psychedelic_Wuff
Dec 29, 2010 03:07 PM
Smokeythebear
1997 - 2003 F150
Jul 17, 2010 12:23 PM
