LED Headlight Lens
Old Nov 10, 2021 | 02:42 PM
old28's Avatar
old28
LED Headlight Lens
I have a 1971 F250 300 inline 6 with 7" round Halogen lights as an upgrade. The Halogen lens look a lot like the original seal beam lens and I like that look. My question is are there any LED headlight lens that look like the original seal beam lens? Also will the LED headlights work with a stock 65 amp alternator? The headlight system has an up grades relay in already.
Old Nov 10, 2021 | 06:06 PM
Pcmdub's Avatar
Pcmdub
LEDs normally use less power than the halogens. I tried the Hella brand sealed glass lens because they are just like stock, but you can swap the bulb to LED. Problem is that most LED bulbs don't project correctly in a halogen lens. There are TONS of LED headlights replacements, but only a couple look like a halogen, and the ones that look like halogen tend to perform worse than the halogen.
Old Nov 10, 2021 | 06:33 PM
FuzzFace2's Avatar
FuzzFace2
Here is some reading really check out the 2nd one.
https://www.ford-trucks.com/forums/1679080-are-led-headlights-worth-it.html
https://forum.garysgaragemahal.com/Lighting-Upgrades-td5689.html
Dave ----
Old Nov 10, 2021 | 06:58 PM
old28's Avatar
old28
Pcm - Do you have a model number for a LED lens that looks like a Hella original 7" look?
FuzzFace2 - Do you have Daniels lighting Email address? Did not see it in the articles?
Old Nov 10, 2021 | 07:46 PM
DisneysPatB's Avatar
DisneysPatB
Look down at the bottom where it says "click here to send an e-mail" Daniel Stern Lighting Consultancy and Supply
Gousetis
22
Oct 6, 2020 12:45 PM
mike85120
Oct 11, 2014 11:33 AM
handifletch
Modular V10 (6.8l)
Oct 30, 2013 12:39 AM
stroker_8
Nov 9, 2010 06:44 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
