E4od pressure
Old Nov 7, 2021 | 05:57 PM
rewiscody's Avatar
rewiscody
E4od pressure
91 e4od, did pressure test at the port once at operating temp and in all selections park through 1st it read in between 80-90psi. Is that normal, I thought there would be more variety to that
also tc isn’t locking up
Old Nov 7, 2021 | 07:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Park, neutral, drive, and 2 should be between 50 and 65 PSI at idle. At stall, drive and 2 should be between 165 and 185 PSI.
Reverse and 1 should be 70-100 PSI. At stall, reverse should be 245-290 PSI. 1 should be 175-210 PSI at stall.
Stall is when the trans is in gear, your left foot HARD on the brake, and your right foot planting the go pedal on the floor. CAUTION: DO NOT HOLD STALL FOR MORE THAN 5 (FIVE) SECONDS AT A TIME!! IDLE OR FAST IDLE FOR AT LEAST 30 SECONDS BETWEEN STALL TESTS.
Old Nov 8, 2021 | 09:18 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Have you checked for codes, even if CEL isn't on, could have stored codes.
Old Nov 8, 2021 | 12:18 PM
rewiscody's Avatar
rewiscody
Yes have egr code and 628 excessive tc clutch shipping.
what would cause my pressures to be steady at around 90 psi at idle,
Old Nov 8, 2021 | 01:41 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The converter has been replaced, according to his other thread.
Old Nov 8, 2021 | 04:28 PM
rewiscody's Avatar
rewiscody
Also have codes 332 617 628. Just re checked
RRE101
Jun 14, 2010 07:57 PM
brownbronco
Nov 18, 2008 07:03 PM
javi2001
Jul 14, 2005 07:45 PM
Clipper508
Jan 21, 2003 06:40 AM
