Please help
Old Nov 2, 2021 | 06:38 PM
OBSorPOS?'s Avatar
OBSorPOS?
Please help
I have a 97 7.3 f350 daully 2wd automatic. My first question is does anyone know about "707" industry's? 2 and main question, my truck at 149,000 miles. bought the truck in ga when i got close to home 3hrs later on NCthe truck's fuel filter light came on, i changed the fuel filter. Now i can start it let it idle for hours Rev the motor all day but after she goes into gear "any" gear she dies, and won't start back up for 10 to 15mins.
Old Nov 2, 2021 | 08:10 PM
Edgethis's Avatar
Edgethis
Never heard of 707 industries.
Was there alot of gunk in the fuel bowl when you changed the filter?
Could be the pump acting up, not keeping fuel delivery up when a load is applied.
Old Nov 2, 2021 | 09:31 PM
OBSorPOS?'s Avatar
OBSorPOS?
The fuel bowl seemed clean. The bowl assembly and the fuel pumped looks like new parts. The seller unfortunately has ghosted me, and im left in the dark.. all my fluids seem to check out too. All functions in the cab work AC/heat, lights, windows. The check engine light came on after the fuel filter replacement.
Old Nov 3, 2021 | 04:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
707 sounds like a scam to me from the little i have read on it.
Old Nov 3, 2021 | 07:18 PM
OBSorPOS?'s Avatar
OBSorPOS?
I did not pay for the 707 its just what the truck has on it
Old Nov 3, 2021 | 07:22 PM
Edgethis's Avatar
Edgethis
Is this a manual or auto trans truck?
Is there a sensor that bumps the idle up on an auto truck? Or is that just controlled by pcm?
Old Nov 3, 2021 | 07:40 PM
OBSorPOS?'s Avatar
OBSorPOS?
The truck is a automatic transmission
Old Nov 3, 2021 | 08:49 PM
bentring's Avatar
bentring
Just to rule it out, have you tried cranking it in neutral and shifting into gear?
Old Nov 3, 2021 | 09:18 PM
Dmco's Avatar
Dmco
@OBSorPOS? welcome to the forum! Sorry about your truck troubles.
The very first thing I would do is find out what codes are causing your check engine light.
For under $30 you can get a bluetooth OBDII adapter and app for your phone to do this. Check out the instructions here:
https://www.ford-trucks.com/forums/1...d-q-and-a.html
Old Nov 6, 2021 | 06:43 PM
OBSorPOS?'s Avatar
OBSorPOS?
Hey thank you too everyone for the pointers. I think i have a torque converter issue. Now i need to know what kind is the best for my truck?
Old Nov 6, 2021 | 09:11 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Without codes, you have no clue what your actual issue could be on the truck.
Best converter? Precision Industries. Period.
Old Nov 6, 2021 | 10:16 PM
BBslider001's Avatar
BBslider001
Checked your trans fluid level? Engine oil level? IPR pigtail?
Old Nov 7, 2021 | 05:28 PM
OBSorPOS?'s Avatar
OBSorPOS?
Checked the transmission fuild seems low. After a visual inspection she leaking at the U joints, and under the converter pin. Not good
97f3501982
Dec 19, 2015 06:54 PM
lindboep
Dec 1, 2015 01:39 PM
tyler0808
Jun 20, 2015 03:10 PM
toysrfords
May 8, 2009 10:15 AM
Lars50
Sep 17, 2004 01:22 PM
