Helping neighbor
Old May 8, 2009 | 07:10 AM
toysrfords's Avatar
toysrfords
Helping neighbor
My neighbor has a 76 ford w/360 that will start but when you try to give it gas or put it in gear it will die.It is hard to start the first time but then will start right back up after it dies.He wants me to look at it tonite and I was hoping you guys could give me some ideas on where to start.Thanks any help
Old May 8, 2009 | 07:14 AM
grandpa'sprideandjoy's Avatar
will it idle in gear or does it die instantly
Old May 8, 2009 | 07:19 AM
Furyus1's Avatar
Furyus1
Almost sounds to me like it's being starved for fuel. Check for puddles under the truck; leaks in the fuel lines; plugged fuel filter; etc.
Old May 8, 2009 | 07:20 AM
that is what I was thinking
Old May 8, 2009 | 07:30 AM
fmc400's Avatar
fmc400
MSEE
Sounds like a vacuum leak.
Old May 8, 2009 | 07:35 AM
toysrfords's Avatar
toysrfords
When you put it in gear it will die but sometimes even in park it will rev a little but just doesnt respond to the throttle like it should
Old May 8, 2009 | 07:57 AM
IZZYAZ's Avatar
IZZYAZ
My 74 F100 with a 360 did that when I first got it running. The fuel pump was bad. It had sat for 19 years in a barn and the diaphragm in the pump dried out and was cracked. So it would still pump a little to get the truck started (hard) and would idle ok, but would stall everytime you tried to rev it or put it in gear.
I would also look into the vacuum lines and possible even the choke. If it has an electric choke it may be stuck closed and starving the engine of air.
Old May 8, 2009 | 08:11 AM
toysrfords's Avatar
toysrfords
Thank you all for the help now I now where to start looking.I try to help him when I can he's in his 70's and is a good one.
Old May 8, 2009 | 10:15 AM
that is what friends are for glad you are helping him out most wouldnot
nateraz1
18
Apr 3, 2011 10:55 PM
1bddelx
Jul 4, 2009 11:40 AM
dslmechanic
13
Jun 25, 2009 01:22 PM
Poohbear
39
Oct 17, 2007 05:43 PM
vamatextech
Mar 6, 2006 07:47 AM
