Hello and TIA for any help. I have a ‘22 F-350 SRW CCLB Platinum with power running boards. I installed an auxiliary fuel tank in bed and I am wanting to add a step so I can fill the tank without having to get into the bed.
There looks to be a place on the frame for some sort of bracket, maybe for the extended running boards. I can fab a step if I have to but was thinking there might be some sort of factory bracket I could get and use.
I am including a couple pictures to see if anyone has something mounted there. This is a long wheelbase and it is located about center between rear wheel and cab.
