side step
Old Jan 28, 2007 | 08:18 AM
scwirenut's Avatar
scwirenut
side step
is there a factory or aftermarket bed step I can get that matches my factory side steps, I cant reach into the back of the bed, I dont want to replace entire side, just add on bed step
Old Jan 29, 2007 | 08:09 PM
ReAX's Avatar
ReAX
There is no good place to mount the steps on the bed. If you do find something that looks close you will have to engineer the brackets. The best looking option you have is Waags kickout duelly full lenght nerf bars. The next option is to replace just the board with a longer one. Westin sells the boards alone in several lenghts, Lengths:
53”, 61.5”, 72”, 75”, 85”, 91”
The brackets on the truck should be slotted for depth adjustments so these boards should bolt right into place. You will need to measure for lenght and build a bracket for the rear most end, but it would look stock and be longer.
