Igntion
Old Oct 22, 2021 | 07:51 PM
williamsleon88's Avatar
williamsleon88
Igntion
I just installed a new ignition cylinder thinking it would fix my problem of when I start my truck it’ll run fine but I let the key go it shuts my radio and all my gauges off. Does anyone know what it could be?
Old Oct 22, 2021 | 11:04 PM
kr98664's Avatar
kr98664
Originally Posted by williamsleon88
I just installed a new ignition cylinder...
Are you talking about the mechanical portion where the key fits? Or the electrical portion further down the column, under the dash?
Old Oct 23, 2021 | 08:28 AM
Franklin2's Avatar
Franklin2
I would change the ignition switch, which is mounted on top of the column, underneath the dash.
1. Take the short cover off around the column that is near the cluster.
2. Important; If you have a automatic, take the small plastic tube with the string off the column. This actuates the PRND21 indicator and is easy to break.
3 Take bolts loose that hold the column to the dash and let the steering wheel drop and down and rest on the seat. You should be able to see the ignition switch on top of the column.
Old Oct 23, 2021 | 08:56 AM
kr98664's Avatar
kr98664
Details for changing the switch are here. Click on the "Ignition Switch" tab:
https://www.garysgaragemahal.com/ignition.html
Note there is a rigging procedure, but it is very simple. In fact, the whole replacement is very easy to do. Remove the trim panel at the bottom of the dash, undo the bracket, and the whole column tilts down for access.
If you want to test the switch while still installed, here's an easy method but you'll need to make one slight change:
https://www.ford-trucks.com/forums/1...on-switch.html
Because your radio and gauges are acting up, it sounds like a different portion of the switch has failed. In my case, the heater fan was misbehaving. I hooked up the meter between fuses 1 and 9 to confirm the respective portion of the switch had failed. For your situation, test between fuses 1 and 11 instead.
Motomamma
Apr 25, 2020 05:07 PM
Lights_Guy3
Feb 27, 2016 01:21 PM
SuperDoodie
May 16, 2009 06:31 PM
95_4x4_jay
Feb 8, 2006 07:25 AM
BoneSS
Jul 10, 2004 03:57 PM
