Ignition problem, maybe?
Old May 14, 2009 | 09:30 AM
SuperDoodie's Avatar
SuperDoodie
Just curious if anyone else has experienced these issues. Every once in a while, when I get in my truck, the dome light is on but as soon as I put th e key in the ignition, everything dies. I have no power to anything, no dash lights, no radio, no dome, nothing. If I mess with the key for a bit, power suddenly comes back. The tach and all my gauges flip all the way over and then return to 0 and I can start it. I also noticed I can pull my key out with it turned on. Its only happened a few times and I can't seem to figure it out. Just wonder if my ignition is bad?
Old May 14, 2009 | 09:33 AM
superduty4x4's Avatar
superduty4x4
Sounds like a safe bet to me Greg. My old 95 I could pull the key out with it running, but never had any problems like you're having.
Old May 14, 2009 | 09:37 AM
Quick444's Avatar
Quick444
If the gauges are flipping all the way over and back, then something is obviously reseting the computer. Something is crapping out for sure.
Old May 14, 2009 | 09:40 AM
megawatt00's Avatar
megawatt00
I had the same issue with my 98 OBS. The cylinder was worn out replaced it and good to go.
Old May 14, 2009 | 09:43 AM
SuperDoodie
Was your also doing funky things with power? Also can they re-key the new cylinder to match my key so I don't have to get new locks for my doors?
Old May 14, 2009 | 09:46 AM
megawatt00's Avatar
megawatt00
It did I would have to wiggle the key at times to get it to run. I bet Ed can match it up via you vin #
Edit: As soon as you put the key into the ignition it sends a signal to the PCM. This is why your keys have to be out of the ignition when removing the PCM
Old May 14, 2009 | 09:47 AM
superduty4x4
They can, though I don't think its particularly cheap.
Old May 14, 2009 | 09:48 AM
SuperDoodie
Is Ed the FTE Parts guy?
Old May 14, 2009 | 09:50 AM
superduty4x4
That's the one.
Old May 14, 2009 | 09:51 AM
megawatt00's Avatar
megawatt00
Originally Posted by superduty4x4
That's the one.
Yup just click on the blue Ed
Old May 14, 2009 | 11:42 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
sure, just send me a vin. I'll check it out for you.
Ed
Old May 14, 2009 | 12:07 PM
SuperDoodie
Ed
Sweet!
Also, I suspect it could be the ignition switch itself too. Does all that come with a new tumbler assembly or is it all separate?
Old May 14, 2009 | 12:18 PM
megawatt00's Avatar
megawatt00
When I did mine Greg I got the whole assembly.
Old May 14, 2009 | 04:34 PM
SuperDoodie
Ok thanks.. I'm sure that is my issue. I could swear it looks like someone tried to steal my damn truck too. Ignition is kinda screwed up..
Old May 16, 2009 | 06:31 PM
SuperDoodie
Just an update..
I installed a new ignition switch today and it fixed all the problems
