Turn the key to start/run and nothing happens.
Old Nov 28, 2005 | 09:22 PM
95_4x4_jay's Avatar
95_4x4_jay
Cool Turn the key to start/run and nothing happens.
I get in a turn the key to start the truck and there is absolutely no dash lights , no radio, no sounds....NOTHING. (not even crickets)
I turn the key backwards to accessory and the radio works. Headlights are bright in either direction.
Try it a few times...5,7, 15 times then for no reason at all it fires right up and is fine.
Battery is strong and connection seems strong too. Happened before and I replaced the ignition switch on spec. about a month ago.
Any ideas??
Old Nov 29, 2005 | 05:19 AM
srercrcr's Avatar
srercrcr
You replaced the key lock cylinder?
I think these trucks have an electrical ignition switch down on the steering column, not sure.
If so, I would replace it....it's cheap and seen better days.
Old Nov 29, 2005 | 07:04 AM
95_4x4_jay's Avatar
95_4x4_jay
I replaced the electical switck block on the steeering column last time it happened.
It was a $20 part.
Old Nov 29, 2005 | 08:31 AM
4.9inline6's Avatar
4.9inline6
is the truck completely in park? i have a ford that looks to be in park but you have to put it a bit further before it will start...sounds to be more of a problem that just being in park but wanted to make sure this wasnt the case before you spent a lot more money and time
Old Nov 29, 2005 | 09:14 AM
95_4x4_jay's Avatar
95_4x4_jay
I "think" it was. It was parked for about 4 days on an incline.
I will be sure to check that out when it happens again.
Is it the MLPS that tells everything what gear you are in? (i.e. Park,Neutral,Drive 1 2 , reverse)
I have a new MLPS but haven't installed it yet. I bought it to remove some questionable tranny sensors.
Old Feb 7, 2006 | 09:12 PM
4.9inline6's Avatar
4.9inline6
did you ever figure out what it was that was causing this?
chris
Old Feb 7, 2006 | 09:38 PM
95_4x4_jay's Avatar
95_4x4_jay
I replaced the ignition switch (cheap part) but it happened one more time. It hasen't happened since.
So...NO.
It might be the truck Auto shift lever not completely in park. Next time it happens I will be more careful to see what is going on.
Old Feb 7, 2006 | 10:49 PM
Bdox's Avatar
Bdox
New means new, it doesn't mean good.
Old Feb 8, 2006 | 07:25 AM
4.9inline6's Avatar
4.9inline6
haha alrighty...good luck!
chris
Comanche1Star
Jun 29, 2014 11:00 PM
jsduty
Feb 14, 2013 01:44 PM
RangerHaywood
27
Sep 15, 2010 05:46 AM
Bucksnort77
2004 - 2008 F150
Jan 27, 2010 07:02 PM
GERRYSLM
2004 - 2008 F150
Feb 3, 2004 05:20 PM
