Tank sender connector
Old Oct 22, 2021 | 09:25 PM
Twintraction's Avatar
Twintraction
4wd High
Guys - I have an '85 F150 4X4 with the 300 c.i. six and four speed manual. Recently bought it and have been going thru it, freshening things up.
The mid tank was a leaker and today I took it down, finding rust within the plastic front cover. Yuck! My question is, how do I disconnect this sender clip without breaking it?
Thanks!! Tom
Old Oct 23, 2021 | 05:16 AM
FuzzFace2's Avatar
FuzzFace2
I hate to say this but it will most likely break no matter how you try not to.
Just go easy lifting it and you may get lucky.
Good luck
Dave ----
Old Oct 23, 2021 | 01:16 PM
BigBlue2's Avatar
BigBlue2
Good luck
Dave ----
Looks different than my sender connection. Yours probably has a catch on the opposite side of the wires. If you can't get an eyeball on it you might need to use a mechanic's mirror to see under the farside in your photo. Looks like lifting the tab on that side will clear the notch. But inspect first.
Old Oct 23, 2021 | 06:35 PM
FuzzFace2's Avatar
FuzzFace2
Same here on the looks but mine is a 81
Now that I am on my computer I dont really know how that comes apart
It almost looks like you lift that part on the far side and slide the connector off side ways?
IIRC mine is rubber and it lifes straight up but its been years since I messed with it.
Dave ----
Old Oct 23, 2021 | 08:16 PM
kr98664's Avatar
kr98664
I looked at several options on RockAuto. It would seem that gray piece lifts straight up from the tank. Not sure how it locks in place, though. It almost looks like it is a separate 90 degree adapter for the small black piece closest to the camera.
Old Oct 23, 2021 | 08:41 PM
BigBlue2's Avatar
BigBlue2
The female plug looks like a replacement with the wires going through those black plugs. My 86 was a total slip fit straight down with no clip holding it. Just a slight negative fit and gravity keeping it plugged in.
audios
Sep 20, 2021 11:06 AM
foofees
Mar 12, 2020 12:08 PM
Resendiz
Sep 4, 2016 12:47 AM
dynamic
Jul 9, 2012 10:25 AM
47,52,69,92
15
Feb 24, 2010 05:54 PM
