2020 6.7 Exhaust Tip. Does it have a function?
Old Oct 9, 2021 | 12:52 PM
see77777's Avatar
see77777
I backed into a bunch of wire that was sitting under a tree and it bent the exhaust tip about 3 months ago. The other day I realized it had fallen off (just the very end foot or so of the exhaust pipe). It’s the double flanged tip. Does this have a function or can I just leave it off for now? Eventually I’d like to have a new one welded on but I honestly and pretty clueless about the exhaust stuff.
Old Oct 9, 2021 | 12:57 PM
Lamoon78's Avatar
Lamoon78
Dont matter
Old Oct 9, 2021 | 01:04 PM
Sanspy's Avatar
Sanspy
The stock exhaust tip on the 6.7 was designed to draw in cool air to keep the exit exhaust temp down during regen.
Old Oct 9, 2021 | 04:36 PM
morepower02's Avatar
morepower02
This is the correct answer.
Old Oct 9, 2021 | 04:41 PM
Lamoon78's Avatar
Lamoon78
And again its not going to hurt anything not being there.
Old Oct 9, 2021 | 07:36 PM
bent-1's Avatar
bent-1
Spot on the mark.
Old Oct 9, 2021 | 07:56 PM
mcmurm's Avatar
mcmurm
I think the stock exhaust tip looks badass. I may be in a minority though.
Old Oct 9, 2021 | 08:11 PM
KU4OJ's Avatar
KU4OJ
Maybe not, as a few gasser people will buy a knock off copy and install that. The little vent things are only for letting in cool air and do not increase exhaust performance in any way. As to does it matter? Of all the things Ford has deleted and repackaged and de-optioned they have left this alone. Must be a reason.
Old Oct 10, 2021 | 04:58 AM
Rich53's Avatar
Rich53
Exhaust temps pulling hard or during Regen are 110 to 1300 degrees, without the mixer you are likely to have 1000 degree exhaust exiting the pipe.
With the Ford tip if they decide the next major brush fire in California is from an SD exhaust climbing a mountain road it is Ford’s problem, without it?
Less onerous but still an issue is someone who gets burned walking behind the truck at a stoplight when the truck is in Regen.
Old Oct 10, 2021 | 07:42 AM
fordman19762003's Avatar
fordman19762003
I don't think the special tip does anything while sitting, only running down the road where the air can flow in through the openings.
Old Oct 10, 2021 | 07:58 AM
C12H24's Avatar
C12H24
Aero past those vanes creates a low pressure area that even at idle will pull outside air into the pipe end. Some time back, I watched videos of Super Duties in stationary regen with flames coming out of the pipe. While the outside air does help cool the gasses, there is a cautionary posted in the owner's manual not to back that b*tch up to a grassy area when doing a stationary regen.
Old Oct 10, 2021 | 08:15 AM
BillyE's Avatar
BillyE
The issue isn’t just about not having the slots. If the last “foot or so” broke off, then it is exhausting somewhere under the truck. If that’s the case, you’re likely to do damage due to the heat. I’d get it fixed. There’s got to be some take offs from people who have swapped exhaust.
Old Oct 10, 2021 | 08:21 AM
B-737's Avatar
B-737
parked regen, 476°
If it were my truck, I would want the proper exhaust tip
Old Oct 10, 2021 | 08:28 AM
llblake64's Avatar
llblake64
When we picked up our new truck that was first thing my wife commented on. She thinks it looks awesome, and I agree.
F250_6.7
Feb 6, 2016 07:51 AM
Dave145
May 12, 2013 09:35 PM
1stimeford
2004 - 2008 F150
Jan 29, 2007 07:15 PM
Lobstah
Jul 17, 2003 01:52 PM
