Steering controls/linkages/elements
Old Oct 7, 2021 | 02:11 PM
Truckerbase's Avatar
Truckerbase
1973 F100 4x4, FE 390, C6 transmission, 2 door standard cab. Has power steering. Dana 44 front axle, Ford 9 inch rear.
Looking into getting new steering control/elements: like center link, drag link, tie rod, and adjuster sleeve. Looking through LMC TRUCKS catalog, I see only one diagram that matches my trucks configuration; but it is under “steering controls-4 wheel drive, 1978-1979 F150 Regular Cab, and 1978-79 Bronco
w/ps (with power steering). Not under 1973 f100 4x4.
Do I assume the farm truck mechanic former owner in Idaho put a Dana 44 axle and steering elements from a bronco or F150 into my truck and carry on with ordering it without further consideration (knowing nothing of mix and match swapability), or am I replacing a problem with the same problem? The old steering elements are very rusted, are missing dust/grease boots off all the tie rod/ball joint linkages, has a large washer like element on driver side tie rod but nothing on passenger side (plus passenger side has notable gap between steering knuckle and drag link)…
Thank You!
Rich1961
Oct 24, 2020 06:48 PM
darren_palms
Nov 13, 2013 09:58 PM
rustybucket'60
Aug 20, 2010 10:30 AM
Sarge89
34
Sep 22, 2009 03:33 PM
rscotth
Jul 26, 2009 08:59 AM
