Steering Stabilizer Field Service Action
I took my truck in for service (2019), and to have two Field Service Actions done on it. First was the Steering Stabilizer and the other was the Carpet Shielding and Insulation Rework. Carpet Shielding was completed, they said they'd replace the Steering Stabilizer after I told them I was getting steering wheel back and forth movement when hitting bumps or potholes. The Tech said upon replacing the Steering Stabilizer that there was excessive movement in the Tie Rod Ends and Drag link, so those are being replaced tomorrow. I never did experience death wobble with the truck, but with the way the steering oscillated and the front end feeling loose when hitting bumps I guess it was just a matter of time.
I had that done to my '19 F-450 pickup in August. The truck drove great but the steering had a lot of feedback when I hit a rough patch of road. The dealer replaced the draglink and steering stabilizer but honestly I can't tell the difference after the fix. Truck still drives great but it still behaves the same when I hit a rough spot of road.
I glad to see there are some good dealers out there that will fix the problem. I have feedback through the steering wheel of something loose when going over bumps. Dealer said everything thing looks tight and no play. Then goes on to say it might be the aftermarket suspension parts. It's an easy way to look away. Sad part is, I only have a dual steering stabilizer and 2" under coil level kit. It took me 2 seconds to find the problem. The drag link end on passenger side has play in it. I bought a moog replacement end and will change it out. I'll then take the failed part in to the service advisor and have a chat. And maybe tell him he better find a new parts changer if he cant diagnose something simple like this.
10,170. Also having Clutch fan issues, running fast all the time. The dealer service writer told me it was "normal" for the fan to do that. I told them BS. I took the Service Manager out for a drive today to show him. He agreed the fan was not supposed to be like that. While on the drive, the truck went into limp mode, hardly any throttle response. No check engine light. Service Manager thinks it has something to do with the fan clutch issue. We'll see.
I really don't know, as I'm still waiting to get my truck back. Hopefully it is an improved steering stabilizer. Fan Clutch was replaced today, and supposed to finish with the drag link/tie rod replacement tomorrow.
The issue with the stabilizers is no resistance when cycling in and out by hand, mine had about a half inch of no resistance. That is the only improvement, just a new one that does not have dead space. If you want better, need to go aftermarket such as fox.
In other words, as long as mine is working, there is no advantage to having the service done. And, if they are just installing the same thing, what keeps it from failing again?
They test the stabilizer before changing it per the tsb, so having them check it out and replace if needed is not a bad thing. However, the new part is still a low cost part, but supposedly updated. May be fine for a while. Recommend looking for tie rod looseness prior to taking it in, pointing out bad joints, and insisting they change them if you receive pushback. In particular look for vertical movement in the drag link.
351Cleveland C4
15
07-15-2013 01:06 PM
