Finished my steering mod- what do you think?
Hello- I haven't been here for so long it's like my first post but I am back and modifing the ole half ton.
Well I just had enough with the TTB tire eating issues and excessive steering wheel play so I dove in head first and modified the steering.
1st thing I got rid of the rag joint which is an eye sore and source of wheel play. I replaced the joint with a real universal joint from Flaming River. Actually this was a piece I had left over from a mustang project.
2nd I bought a rebuilt steering box and installed it.
3rd New caster camber bushings from Bronco graveyard
4th since I am lifted about 4"-5" I needed to address the crappy tie rod angles that eat the tires by designing my own steering system since there is no real good aftermarket.
End result is a "K" type steering with DOM parts from BulletProof Steering and their rod ends. Yeah it's a bit over kill but looks beefy as well. The end result is the "tie rods" are in the same radius as the IFS axle! This was a pretty involved mod that utilizes an idler steering gear on the passenger side. this actually started out as a super runner steering but it didn't totally correct the steering geometry- just helped. It also used factory type rod ends which aren't that great to start with.
Next will be a roller motor install with a cobra computer......................
on
http://www.superlift.com/accessories/superunner.asp
Yes- I originally had a super runner system and it helped with angles but didn't correct the problem. The super runner uses a swing arm on the passenger side with a soft bushing. I am using an idler stering gear- just for rigidity and strength. I have also eliminated the factory type tie rod ends.
The truck drives well and the steering is tighter than factory. The geometry should address the tire wear issues too.
Nice linkage BTW- it's a big, mean, scary looking linkage! Not small and puny like my factory set up!
That thing on the passenger framerail is an idler arm, guys...quite a common thing to see on cars in the days before rack-and-pinion steering. It keeps the drag link moving in the same plane every time the steering wheel turns, which should lead to a better-steering vehicle.
I don't know what the engineer who came up with the IFS steering linkage was smoking, but the above setup looks like it should conceivable cure a lot of ills in the stock steering.
Pat
Pat
Dr G
57
06-21-2022 03:55 PM
AMG-SM
61
08-14-2017 03:00 PM
19tanker
08-17-2015 04:21 PM
