burnout
Old Nov 2, 2003 | 09:19 PM
96F250pwrstrkdiesel's Avatar
96F250pwrstrkdiesel
Unhappy burnout
This may be a stupid question but i have a 96 F250 power stroke diesel, sowhat i wanted to know is if anybody knew how to burnout on it???? I tried power braking but it doesnt seem to work
Old Nov 2, 2003 | 09:25 PM
F0rdF0rever's Avatar
F0rdF0rever
Thats not a good idea to begin with. Its not a race car. Bringing the rpms up and past 3000 could eventually be harmfull. But if you must know... I dont think it will completly stock.
Old Nov 2, 2003 | 10:13 PM
Larry Heath's Avatar
Larry Heath
There is really no reason out side of saying that you can or did do a burnout to do one. A burnout is designed to heat racing rubber compounds which contain what are called oils and bring them to the surface of the tire to gain traction, even then this is really only effective on tracks that have be prepared with traction compound and by many racing tires also laying sticky rubber down on the surface.
But if you must do a burnout, you need to put a line lock in the front brake lines so you can lock the front brakes while the rear brakes remain off. Press on the brakes hard, press a switch and it locks the front brakes. Then hamer down on the throttle and I am pretty sure you will get some smoke, and more than likly broke parts as well, being that the suspention isn't setup to deal with this type of application of power, likely you will endup with tire hop do to spring wrap-up. Try www.summitracing.com for straters they have more than one style of line lock I am sure.
Later Larry
Old Nov 3, 2003 | 03:22 PM
96F250pwrstrkdiesel
Thanks for the advice Larry Heath and FOrdFOreve. But I have another question. On this same truck I was wanting to put a dual exhaust system and i know that this will help improve gas mileageand hp on gas trucks but will it work for diesel trucks???
Old Nov 3, 2003 | 09:11 PM
Ggg6's Avatar
Ggg6
Unlike on a gasser, your two exhaust manifolds meet into one exhaust at the turbo. So putting a dual exhaust after the turbo will do nothing compared to a proper sized single on a turbo charged engine. If you want a good sounding and good flowing exhaust on a PSD go with a straight 4" pipe. The straight pipe is kinda loud for some people but most like it. The duals you see on a PSD are only for looks not performance. So if you must have duals just install a wye before the "over the axle" pipe and run the second pipe where you want.
PS. A stock 96 certainly will do a nice burn out. Even if it was for no particularly good reason other than to prove to my son that his old man still had it in him.
Old Nov 3, 2003 | 09:19 PM
96F250pwrstrkdiesel
LOL Ggg6 how did you do your burnout?
Old Nov 3, 2003 | 09:46 PM
Ggg6's Avatar
Ggg6
Break torque to get it started, once good and hot let off the brakes and ride it out. I did a 85' posi in my driveway. Yeah the old lady was proud of me that day.
ceetwarrior
Sep 28, 2014 10:05 PM
78250crewcab4x4
Offroad & 4x4
18
Jan 13, 2009 08:14 AM
Big_Man_Brad
Jun 2, 2008 06:36 PM
tjthegreat
40
Mar 9, 2008 11:01 PM
TheTedster
Appearance & Dress-Up
Jun 17, 2007 03:09 AM
