Not using WDH
Old Sep 30, 2021 | 10:48 AM
hillcountryflt's Avatar
hillcountryflt
Not using WDH
Recently acquired my first super duty in about 20 years - a 21 f250 fx4 crew with 7.3 and about 2,800 pounds payload and optional 3.55 electronic differential rear end.
I have a 31 foot travel trailer with tongue weight of about 750 or so pounds and trailer weight is around 7,000 pounds (listed at 6,300 and we don't carry water).
I have dropped the trailer on my hitch without using the wdh and it doesn't squat it much.
Would it be wise or practical to eliminate the WDH and just activate the truck's built-in anti-sway features. I disable them when towing with the WDH.
It would not break my heart to not use the hitch.
Popular Reply
Sep 30, 2021, 01:02 PM
cpobst's Avatar
cpobst
Originally Posted by Norris McCarty
In my opinion and after many years of experience(I've owned an RV dealership for many years), I'll make a bold statement to say that "weight distribution hitches are for folks pulling trailers that are in reality too large for their truck".
I'll leave it at that.
Carry on.
Im guessing your the same guy selling 36' TT's to anyone with a 1/2 ton cause their "rated" to tow that much? Not derailing this conversation but your statement takes away any credibility you have in this conversation.
Old Sep 30, 2021 | 10:52 AM
cficare's Avatar
cficare
Try it once and you'll quickly reattach the WDH. It's amazing how the towing stability increases with a WDH even though tongue weight is OK without it.
Old Sep 30, 2021 | 11:00 AM
davidpacificnw's Avatar
davidpacificnw
yeah, not 100% why they call them "weight distribution" hitches. They should be called "weight distribution and stability" hitches. As the poster above stated, basically try it. I recommend trying it on a long tow with wind. And make sure you keep you WDH in the truck. You'll be installing it at the next rest stop after a 10+ mph cross wind. Good luck
Old Sep 30, 2021 | 11:03 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I tow heavier than that without the WDH.
You can go with or without, but it'll probably ride better with it.
I never have any issues with stability, if you do then something is wrong and you need to stop and figure out what.
Old Sep 30, 2021 | 11:06 AM
hillcountryflt
I will say I was amazed I had to make no changes in my WDH (Equalizer 4) settings when I moved from my 2020 4x4 f150 Lariat to this truck.
Old Sep 30, 2021 | 11:36 AM
pauliwalnuts's Avatar
pauliwalnuts
Yea I didn't have to make any changes either going from a 2021 F150 to a 2021 F250. I agree with others if you are towing an RV I wouldn't even think about towing w/o a WDH/Anti Sway hitch.
Old Sep 30, 2021 | 12:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
You should also ask this question in the towing forum.
Old Sep 30, 2021 | 12:04 PM
6.2caribou's Avatar
6.2caribou
We have a Jayco 236TH that's in your same weight range. With two 30lb propane tanks and 2 group 27 batteries, tongue weight exceeds 850 lbs. We pulled it from PA to CO/NM/UT and back this spring, with 2 trips over Wolf Creek Pass...5k miles, with just a B&W ball hitch. I did replace the helper spring pads with 2.25" bump stops, which allows them to engage with the trailer on the ball. Squat is minimal, as is sway from wind and passing trucks...not significant enough to make me want to deal with the complexity of hookup/cost of use of my wdh.
Old Sep 30, 2021 | 12:09 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I’m in a similar situation, but knew I would still use a WDH even with my more capable truck. I have a 6000 lb GVW camper and my F250 with all the extra packages make it actually a 350. However, a new WDH was one of the first things I bought when I got mine. However, I went with the Anderson WDH. It will offer excellent sway control and still distribute some weight back to my front axle, which should make for a nice stable tow. Plus, the new hitch will have a 3” shank so I won’t have to use reducer sleeves and it only weighs 60 lbs, so a lot lighter than my old WDH.
Old Sep 30, 2021 | 12:40 PM
Desert Moto's Avatar
Desert Moto
"It will offer excellent sway control and still distribute some weight back to my front axle, which should make for a nice stable tow." (Chadstickpoindexter)
This is the main point to having a WDH. Hooked up and towing slow speeds not much need for one, but traveling at speed and going over undulating highways will start to load and unload the hitch point with much more force than just a static load. Your trailer weighs more than your truck and hanging from the worst place to tow from.
Old Sep 30, 2021 | 12:49 PM
Norris McCarty's Avatar
Norris McCarty
Carry on.
Old Sep 30, 2021 | 12:53 PM
cficare's Avatar
cficare
When I used to pull a 24' box car trailer, the WDH made a huge improvement even when the trailer was empty. The only times I didn't use the WDH was when pulling an unloaded open 18' car trailer .
Old Sep 30, 2021 | 12:54 PM
jb3451's Avatar
jb3451
I tow a 9500 lb. enclosed car trailer and stopped using my WDH when I purchased a Weigh-Safe hitch (3"). The bumper pull tongue weight is 1100 lbs. and in the two years pulling over 10k miles I have never had any problems with sway at all pulling @ 70 mph. So it is totally possible (if you have the right equipment and balance) to pull with just a ball. The bonus is simplicity and being able to easily unhook at the track to go to the hotel or get some chow. Everyone has a different situation so your mileage my vary, happy towing!
Old Sep 30, 2021 | 12:57 PM
nickshu's Avatar
nickshu
Thanks for this. I tow a race trailer too and the WDH is a PITA to deal with. I am considering trying the WeighSafe hitch and airbags. I may miss the sway control, but not dealing with the WDH.
Old Sep 30, 2021 | 12:59 PM
hillcountryflt
As an alternative to the air bags might look at the Roadmaster Active Suspension System.
