Not using WDH
Old Oct 1, 2021 | 07:37 AM
  #46
Fmc128's Avatar
Fmc128
I pull a 40ft travel with my 450 hook and go
Old Oct 2, 2021 | 12:04 AM
  #47
RubenZ's Avatar
RubenZ
I dont use a WDH. But my trailer is only 24ft. And 5000#. I do have one though. I just dont need it at this moment with my trailer. It’s a PITA to setup especially in 100 degree south Texas heat. I’d rather just hook and gooooooo
Old Oct 3, 2021 | 10:34 PM
  #48
Keokie's Avatar
Keokie
Towmeister,
Ive never had trouble with WDH's and saltwater. My saltwater excursions have been limited, but I found salt-away and Corrosion X worked great with the hitch.
Boats tow much better than box and camper trailers. This is due to the axles on a boat trailer being much further back (as that is where boats are heaviest), and a boat is much more aerodynamic. These two differences make boat trailers porpoise far less and sway from passing semi's far less. Still, less is not none. And placing weight back over the steer axle has big benefits in safety and comfort.
I routinely pull a boat on triple axle trailer that weighs in excess of 20,000lbs. Even with a 450, the WDH makes a noticeable improvement in ride and handling.
Old Oct 25, 2021 | 09:35 PM
  #49
markp59's Avatar
markp59
Yes you need a WDH
Originally Posted by hillcountryflt
Recently acquired my first super duty in about 20 years - a 21 f250 fx4 crew with 7.3 and about 2,800 pounds payload and optional 3.55 electronic differential rear end.
I have a 31 foot travel trailer with tongue weight of about 750 or so pounds and trailer weight is around 7,000 pounds (listed at 6,300 and we don't carry water).
I have dropped the trailer on my hitch without using the wdh and it doesn't squat it much.
Would it be wise or practical to eliminate the WDH and just activate the truck's built-in anti-sway features. I disable them when towing with the WDH.
It would not break my heart to not use the hitch.
The pickup is designed to have its load in the bed over the axle, not hanging out past the bumper on a ball hitch, thats why a WDH is needed to conter-act that force. If you picture the truck alone, with a 1000# load on the ball hitch, the truck will be unstable to swerving because you moved its center of gravity backwards. Its *** heavy and will fish tail if you goose it with a swerve of the steering wheel or if the trailer gooses it from wind pressure from a passing semi. You increase your chance of an out of control sway(search for videos on youtube).
Your goal is to get the truck front axle weight with the trailer connected equal to the truck front axle weight with no trailer. Or saying it another way, you are restoring the weight to the front of the truck that applying the trailer lifted off of it. You can estimate this by measuring fender height with and without trailer, but a scale that weighs the front axle alone is more accurate, especially if the trucks front end is stiff.
I would bet the tongue weight is going to be more than 750 pounds for a 31 foot travel trailer. Taking it to a scale will show that...
Old Oct 26, 2021 | 05:52 AM
  #50
SeniorRVer's Avatar
SeniorRVer
Originally Posted by HRTKD
Agreed.
The loss of weight on the front axle due to a bumper pull trailer can have a huge effect, especially in emergency situations.
This is rarely mentioned, and IMO, the most important feature/protection of a WDH.
Sure, most of us could do without in many instances, but when $his hits the fan? The saying of, "there are no atheists in foxholes" comes to mind.
I'm retiring SOON from a career in truck driving, and one thing is certain, there is no shortage of STUPID out there on the roads!
With a 4,508 payload rating, and a 1,200lb tongue wt..... I could do it ... but why?
My new truck & new TT represents a $100K investment, in addition to my riders, and the traveling public around me. WDH for me please!
Old Oct 26, 2021 | 06:43 AM
  #51
GM in a Ford's Avatar
GM in a Ford
Originally Posted by ShotgunZ71
Using a properly set up WDH, in addition to the vehicles built-in anti-sway features, is the best of both worlds and will normally result in the most pleasureable towing experience. I've tried it in every combination and that is what had the best stabilty, best ride, etc.
My WDH with built in sway-control says to turn off the truck sway control feature so I do.
Old Oct 26, 2021 | 06:46 AM
  #52
cpobst's Avatar
cpobst
What model are you running?
Old Oct 26, 2021 | 06:51 AM
  #53
DailyDually's Avatar
DailyDually
7th Gear
Considering the ratio of the distance from rear axle to ball hitch and rear axle to front axle, if you add 1000 lb to the ball hitch, that unloads no more than 300-350 lb off the front axle, correct? That’s less than the difference in weight on the front axle between a diesel and a gas engine. Why would a diesel truck need weight distributed to the front axle in that situation when it still has more weight up front due to the engine than a gas truck?
Old Oct 26, 2021 | 06:53 AM
  #54
cpobst's Avatar
cpobst
Because when you're going down the road the porpoising will unload that front axle even more. A WDH prevents that.
Old Oct 26, 2021 | 06:59 AM
  #55
DailyDually
7th Gear
Anyone have actual calculations of that effect? We can calculate the static effect of weight easily, how much dynamic force is applied when porpoising? My towing experience with a 34 ft trailer is only with long bed crew cab models. I never felt much difference in the porpoising effect with or without a wdh.
Old Oct 26, 2021 | 07:06 AM
  #56
cpobst's Avatar
cpobst
I would say it would be a challenge to do that due to so many variables. I will admit that I have not towed long distance with my 450 yet but when I had my 2017 F250 short bed I definitely had that experience and I did not like it. In the end it is all about perspective though and what you are use to. If you have never used one then you are use to the way it drives. If you have you are use to having that solid feeling and not bouncing up and down. I am sure all of us who camp has seen the Ram 1500 with airbags towing a 40' fifth wheel because they have air bags and it barely squats. They have themselves convinced that it tows fine and they experience no negative effects.
Old Oct 26, 2021 | 07:15 AM
  #57
Chris 86's Avatar
Chris 86
My Blue Ox manual says the same. I have tried it both ways, and noticed no difference. It would be nice the know the science behind the instruction.
Old Oct 26, 2021 | 07:18 AM
  #58
DailyDually
7th Gear
If you aren’t incorrectly loading the trailer to cause self-propagating sway, the truck’s system probably never activates. The passive friction in the wdh to make the swaying motion more difficult is doing all the work.
Old Oct 26, 2021 | 07:20 AM
  #59
GM in a Ford
I have an EAZ-LIFT (link below). It had a tag on it when I got it that said to disable the truck's sway control.
EAZ-LIFT
Old Oct 26, 2021 | 07:30 AM
  #60
Chris 86's Avatar
Chris 86
Exactly, not sure why they suggest it then. The only thing I could think is maybe if there is sway, the timing between the truck counter measures, and the natural sway reduction could be offset is such a way that it would amplify sway?
