Ignition coil boot separated
Old Sep 29, 2021 | 01:26 PM
JimmyCornCrack's Avatar
JimmyCornCrack
Hey folks- new-timer here, and am in the middle of this very grueling v-10 spark plug change on an E-350 Super Duty.
The last coil I was removing came apart. Go figure. I got the lower piece out. It looks like it just presses back together just fine. Nothing broken or damaged. Is that ok to do? Just put it back together and reinstall?
Thanks!
Old Sep 29, 2021 | 02:46 PM
RazorsEDGE's Avatar
RazorsEDGE
It's ok, but you should replace the coil boots when you do spark plugs anyway.
Old Sep 29, 2021 | 03:17 PM
JimmyCornCrack
Thanks! Just the boots, or the whole coil?
Old Sep 29, 2021 | 03:23 PM
RazorsEDGE's Avatar
RazorsEDGE
Just the boots.
Old Sep 30, 2021 | 04:36 AM
JWA's Avatar
JWA
You'll want to use just a dab of dielectric grease at the spark plug end---this helps seal moisture out of that area. I use just a bit inside the upper end fitting around the COP body as well as inside the wiring harness connector.
Old Oct 3, 2021 | 12:13 AM
maples01's Avatar
maples01
Yes grease them, mine had 2 coils fail, upon removal they appeared to have collected water in the well, likely shorting them.
Old Oct 8, 2021 | 02:20 PM
FnESeries's Avatar
FnESeries
Wow, I just pulled a few coils to check the condition of the plugs on this new to me 2006 5.4l, I was surprised to see debris around the upper part of the coil boot (outside of the bore) how does stuff get up in here? Is there a route for small leaves/pine needles to fall this deep or does it all dust up at road speed from below? and my 'Wow' was at hearing that water worked its way up there!
Old Oct 8, 2021 | 04:58 PM
maples01's Avatar
maples01
Yeah, can't prevent it as you can't see how it got there, but its obvious by a chalky white color on the boots, which is corrosion from the aluminum intake, I had first thought it was coolant, but can't be as its mixed with ethylene glycol. So far I've had no issues, at least the miss has gone, I wish I knew which cylinders had the water in the plug well so I could monitor it.
darcrysd
Sep 1, 2014 09:44 PM
scottblogs
Apr 24, 2014 10:24 AM
traxx808
Aug 17, 2009 06:38 PM
kalawikimaui
Jun 26, 2008 04:35 AM
bennyhick2
Modular V10 (6.8l)
Mar 5, 2007 05:18 PM
