Modular V10 (6.8l)
v10 ignition coil
Old Feb 4, 2007 | 09:35 PM
bennyhick2's Avatar
bennyhick2
Smile v10 ignition coil
I had a miss in my engine it actually shaked the truck going down the road. I paid sombody to diagnose it. Misfire on cylinders 2,7 so I replaced the ignition coils on them cylinders, but I cheaed out and bought them from Advanced auto parts half the price. Well that was 2 moths ago and now it it misses again but not bad enough to kick th engine light on so I figured I would buy 1 ford coil and install it to replace 1 of the advanced coils. Helped a little but thinking it may also be the other advanced coil. I found on ebay a company called Global Automotive and their offering 10 oem coils and 10 motercraft plugs for $155.00. I emailed them to see where the coils come from and they answered that their made by Visteon in Europe. Kinda scared to buy somthing after market has anybody ahad any dealings with these companies or these product? How about some opinions thanks
Old Feb 4, 2007 | 10:04 PM
biz4two's Avatar
biz4two
Arrow
What kind of FORD are you driving?
How many miles?
Need more info...
biz
Old Feb 4, 2007 | 10:54 PM
joe_jeep's Avatar
joe_jeep
visteon is ford. or was till recently. should be oem coil
Old Feb 4, 2007 | 11:07 PM
Racerguy's Avatar
Racerguy
Welcome to the forum Benny
How many miles on the spark plugs? Spark plug problems are way more common than coil problems.
Old Feb 5, 2007 | 08:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd certainly look into the plugs on those cylinders, at the very least.
I'd check if they are white (too lean) too - as in, the injectors aren't firing right (or dirty).
It sounds like the plugs are rusty or dirty around the insulator...
Before spending more money on coils, change those plugs out...
In my opinion, it's just as scary buying Motorcraft brand parts as it is aftermarket
Old Feb 5, 2007 | 05:51 PM
bennyhick2's Avatar
bennyhick2
Yeah your probably right I should try the sparkplugs first. I guess I just get rapped up in all the new technology and forget about the basics. I'll keep you posted.
I have a 2001 f350 4x4 ext cab
Old Feb 8, 2007 | 03:28 PM
Fleetsuper's Avatar
Fleetsuper
Absolutely, Visteon is the OEM supplier to Ford for many, many items.
Buy with confidence,
Old Feb 22, 2007 | 03:55 PM
johnnybecool's Avatar
johnnybecool
I replaced 2 coils at $55 each. My truck has 200000 miles with a rebuild about 3000 miles ago. I figured what the hell, who knows the history of my coils, therefore I bought 8 more on eBay from Global, now it runs like a kitten. No relation to Global. This is my honest answer. Good Luck, John
Old Feb 22, 2007 | 09:02 PM
993/4ton's Avatar
993/4ton
Hey benny, before you spend a bunch O' money on new coils all the way around, have you tried just replacing the rubber boot inside of the coils. This is also a likely culprit for your problems. These insulator boots crack and allow misfires to occur. They are cheap, too! I believe you can get them at your local parts house.
Old Feb 22, 2007 | 09:32 PM
bennyhick2's Avatar
bennyhick2
Hey fellas I talked to a guy I know from the local Ford dealership. He said that 9 times out of 10 if a coil goes bad the plug getts shorted out too. So I replaced the 2 plugs on the cylinders that I changed the coils on. It made little of no change at all so I gave the deal I found on Ebay a try and it has been successfull this far. Thanks for all the helpfull suggestions.
Old Feb 22, 2007 | 11:04 PM
993/4ton's Avatar
993/4ton
Isn't that the job of a spark plug? to short out over the gap? Was this guy a tech?
Old Feb 22, 2007 | 11:29 PM
Racerguy's Avatar
Racerguy
In my experience 9 times out of 10 the problem is just the spark plug and not the COP.
Old Feb 23, 2007 | 12:08 PM
krewat's Avatar
krewat
Maybe not so much "shorted out" as "fouled". And who wants to spend 10 minutes cleaning a plug when they are so cheap compared to the tech's labor?
Old Mar 4, 2007 | 07:02 PM
robottommy's Avatar
robottommy
Bennyhick2,
Did you buy the COP/plugs from that Ebay company?
Just want to know.
Tom
Old Mar 5, 2007 | 05:18 PM
bennyhick2's Avatar
bennyhick2
yes I did and so far they work great. I just orderd a set for my dads truck over the weekend. I actually talked to the company on the phone this time and they assured me that they never had any of them come back, and I was told that they supply many comanies accross the country.
RL7
1997 - 2003 F150
25
Jan 6, 2025 02:15 AM
westend
Feb 14, 2018 12:32 PM
Todd1577
Jul 12, 2017 05:22 AM
RSCHAP1
Sep 6, 2016 04:56 AM
abe
Jan 1, 2013 04:51 PM
