ignition coil
Old Aug 17, 2009 | 02:49 PM
traxx808's Avatar
traxx808
ignition coil
i have a used msd coil i think the part # is 8227 on it is the name blaster tfi..........i hooked it up to a 94 f150 & it did not start up checked the connections & there was only two on the factory plug & two on the coil & reconnected the factory coil & it started right up..........is there the possibility that the msd coil could be burned out or do i need a msd ignition box to complete the ignition circuit.......any comment on this matter is appreciated.............thank you in advance...........
Old Aug 17, 2009 | 03:19 PM
lew52's Avatar
lew52
You don't need the box to run a tfi blaster coil , so its more than likely a bad coil ... Lew
Old Aug 17, 2009 | 06:38 PM
1966Tbird's Avatar
1966Tbird
any canister style ignition coil will work, you don't need to have the special one for our trucks just snip the plug off and put on the appropiate connectors and your good
