Lots of white smoke from exhaust
Howdy all,
My ‘63 F100 292 is billowing white smoke from the exhaust. Lots of white smoke. It is constant - not just when it starts. It smells like … exhaust, I guess. I’m not smelling oil, and I don’t see a blue tint.
I’d be grateful for ideas of what is going on, and is it serious?
Thanks in advance.
Mike
Thanks in advance.
Mike
The following users liked this post:
If in fact you do have a blown head gasket the coolant may be a bit low and you are not holding coolant pressure. The coolant system can be pressurized to check and verify you are leaking. I strongly suspect head gaskets with white smoke. You need to park it and verify the problem. as stated above a fairly inexpensive fix can get costly if you hydrolock that engine. Things will break.
The head gasket isn't a big deal as far as fixing, but you do not want antifreeze in the oil, it will destroy the bearings. I wouldn't start it anymore until you find the issue. If this just started happening it isn't a freezing problem, so I'd assume the head gasket is bad, that's a pretty easy engine to work on, drain the oil make sure there is no sign of antifreeze, then pull the intake and the heads. IT's a good time to send the heads to the machine shop have the valves done and plane the heads.
The following 2 users liked this post by EricJ:
Thanks to all. I'm going to have to take this to my mechanic, as the steps involved are beyond me. For my education, some specific follow ups ...
@lizardman1 I pulled a plug last week and it didn't have residue, but looked black. Pic attached.
@MikeyLawless nope ...no deisel!
@EricJ I can change the oil ... if I do, how will I know if there is antifreeze in there? And if there is, does that mean head gasket or something else?
@Jimmy's Pilot Service got it. Coolant looks low - can't touch it with my finger.
All ... the smoke is white-ish. Not Puffy white smoke like steam from a stack ... maybe it is oil? if it is, does that mean valve seals?
