1965 Electric Schematic Flasher
Old Dec 2, 2016 | 05:48 AM
911tom's Avatar
911tom
HI,
i need to install the emergency warning flasher system/turn signal in my 65 F100.
Does anyone had done this before ?
Also i need a schematic for the flasher system.
Thanks alot.
Old Dec 2, 2016 | 09:58 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The emergency warning flasher system is a separate plug-n-play setup that plugs into your existing wiring harness, assuming that's intact. Do you have working turn signals? You can work on turn signals as a task unto itself and then add the emergency flasher circuit.
Here's one of the vendors that has your part number in stock and you can buy it online. NOS Parts Ltd. Tell them Chad in Seattle sent you. Lol.
C5TZ-15B590-C - 65/66 F100/250 (except 4/W/D) Before Serial 858,001.
C5TZ15B590C | SWITCH AND WIRING ASSY.-EMERGENCY WARNING FLASHER | $78.59
Mark Miller also has one. You'd have to call him and check on a price.
(607) 722-5371
Same part number has been mentioned before in a couple of other threads.
https://www.ford-trucks.com/forums/s...rchid=23543044
Old Dec 4, 2016 | 03:16 PM
911tom's Avatar
911tom
thanks alot, yes turn signals work.
Does anyone have a schematic of the turn signals ?
Old Dec 8, 2016 | 03:54 PM
charliemccraney's Avatar
charliemccraney
A shop manual will have wiring diagrams, and is a necessary tool. They're available at most vintage Ford parts places
ru67
May 28, 2016 12:21 PM
Fran loves Fords
Oct 8, 2015 09:04 AM
dan66tampa
Jan 23, 2005 08:42 PM
jaybender
Jun 1, 2004 10:18 AM
66worktruck
Nov 4, 2001 09:15 PM
