manual or power steering Mii
Received 4,181 Likes
on
on
Tell us a little more about your truck and your intentions . Engine , is this something you will do yourself with salvage parts or pay someone to do with off the shelf parts ect . Flatheads or y blocks will quite likely need fabricating of ps pump brackets and lines . I personally would not be without ps but if I was starting from scratch electric would certainly be on my radar .
Power steering with 17" steering wheel
I have MIi suspension with power steering rack, using pump from my 90 Crowm Vic donor, 5.0L.
i have the 17" steering wheel, and steering is quite sensitive.
i am currently switching my truck back to stock suspension and steering. Going to try going with manual steering at first.
I would agree with ebear. I'm not aware of large scale complaints, and I believe most kits today utilize the later model Mustang or Thunderbird rack, which offers a much better road feel ratio than the earlier cars. If I were going to the trouble and expense of setting up a new front suspension, I would take full advantage of all the improvements and go with power R&P steering. As mentioned above, make sure your pump is matched to your rack's needs and you should be fine.
power steering
I had 5 --1953-55 Ford F-100 All built with FORD 302-- Mustang II front suspensions tubular A-Arms-- C-4 trans -- C-6 with small bell housing --Explorer rears 3:08--3"26) disk brakes --use CVF racing front pulley set-up-- Saginaw PS pump ( internal reducing valve )-- I and buyers that bought them have everything good to say about the super handling and great safe ride-- would NEVER--NEVER build one with out this set-up-- GOOD LUCK on your choice
wallerhe
03-25-2014 12:37 AM
beckman
04-17-2013 11:54 PM
LoneStarTrucker
05-09-2008 06:08 PM
roy123
08-05-2007 08:31 PM
baitmaster
03-31-2003 07:59 PM
