Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
LN700 decode
Old Nov 23, 2020 | 03:50 PM
Smartie780's Avatar
Smartie780
LN700 decode
Looking for VIN decode help please! I sell parts for a living and people keep bringing me their questions ha ha
N718BVEE6767 (Mod edit--engine code is B, not 8)
Thank for your help!!
Old Nov 23, 2020 | 04:32 PM
85e150's Avatar
85e150
N718VEE6767
Welcome to FTE!
Is this a Canadian market truck?
Old Nov 23, 2020 | 04:51 PM
85e150's Avatar
85e150
From the '73-'79 Ford Master Parts catalog:
N71 = 1975 and newer LN700 gas
8 = Cummins NTC 350 6 cylinder diesel. (conflicts with N71 saying this is a gas truck) SEE POST 5. ENGINE CODE IS "B"
V = Kentucky Truck Plant
EE6767 = 1979 series number.
Do you have a diesel or gas?
If it's a Canadian market truck, that would explain a mismatch.
Last edited by 85e150; Sep 21, 2021 at 07:24 PM. Reason: OP update with warranty plate
Old Nov 24, 2020 | 08:25 AM
Smartie780's Avatar
Smartie780
Welcome to FTE!
Yes! It will most likely be a Canadian Market truck. And yes it's a gas engine.
Thanks for help!!
Old Sep 21, 2021 | 07:11 PM
Smartie780's Avatar
Smartie780
So it is a gas, and I am getting conflicting info on what year it is. I thought it might be a 75? HEre is the complete body plate. I am trying to track down a ignition for it.
thanks!
Old Sep 21, 2021 | 07:44 PM
85e150's Avatar
85e150
Posts merged. So once more from the top:
B = 370 4V gas V8
220 = 220 inch wheelbase
C = Special white
N710 = LN700 gas 21,000lbs GVWR
8A8 = Standard cab without butterfly hood. I do not have upholstery or seat info
M = Clark model 285V five speed direct transmission
534
53 = Rockwell (Timken) rear axle, model H-172, 17,500lbs capacity, 6.17 ratio
4 = Ford front axle, 12,000lbs capacity, without power steering. (this seems wrong. with a GVWR of 21,000, there is no need for a 12,000lb capacity front axle. Typo on the warranty plate? Typo in the copy of the MPC sample I have? Hard to tell)
21000 = 21.000lbs GVWR
87 = Body company. Sold to a company to add back of cab equipment.
Does this match up with what you have?
Old Sep 21, 2021 | 07:45 PM
85e150's Avatar
85e150
thanks!
It's a '79. Are you looking for the ignition switch or under the hood ignition parts?
Does the title match this plate?
Old Sep 22, 2021 | 11:38 AM
Smartie780's Avatar
Smartie780
We are looking for the wiring harness and the piece it connects to up to the ignition lock cylinder. Left side of the dash for some reason. And yes all of that info looks correct, I will have to check into that axel comment. "4 = Ford front axle, 12,000lbs capacity, without power steering. (this seems wrong. with a GVWR of 21,000, there is no need for a 12,000lb capacity front axle. Typo on the warranty plate? Typo in the copy of the MPC sample I have? Hard to tell)"
thank you so much for your help!
Old Sep 22, 2021 | 12:31 PM
Smartie780's Avatar
Smartie780
It looks like it could be a sw944 ignition starter switch but want to make sure before I order it. My parents live in a small town and options are very limited
Old Sep 22, 2021 | 01:43 PM
85e150's Avatar
85e150
Possible source for diagrams.
https://www.faxonautoliterature.com/...-NT8000-NT9000
Johnytrucker
Large Truck
Jul 27, 2021 01:26 AM
John Atkins
Large Truck
Jun 9, 2021 03:15 PM
MDSuperDuty
Jul 2, 2012 08:26 AM
custom1
Sep 8, 2006 06:42 AM
cwb60
Nov 5, 2002 10:43 AM
