Attention New York Diesel Owners.....
Maybe this is already known but when I scheduled my inspection yesterday the mechanic asked me "Gas or Diesel" which I replied gas. He then proceeded to tell me that as of some date I believe in July Diesels under 10,000lbs will be subject to full emmissions testing. The other part is they are requiring the testing on all diesels back to 1996 when OBD came out!!! So those with all the emmission delete stuff I hope you can get it put back on for the inspections!!
Just did a search and I think that this is what this is about. Here is the link to the entire brochure. NYS DMV - (Brochure) New York State Vehicle Safety/Emissions Inspection Program for Cars and Light Trucks
On-Board Diagnostics - Version II (OBDII) Inspection. The emissions inspection for vehicles registered anywhere in New York State includes an "OBDII" (on-board diagnostics) test for vehicles that weigh 8,500 lbs. or less, and are model year 1996 or newer. Part of this test examines the Malfunction Indicator Lamp (MIL), also known as the "check engine" light, for operation/illumination, and verifies the test results of the vehicle's "on-board emissions diagnostic" system.
Low Enhanced Inspection. A "Low Enhanced" emissions inspection is required for most other vehicles, unless they are subject to the OBDII test or are exempt from all emissions inspections. This inspection is required for all vehicles from and including model year 1995 and older, through and including vehicles that are up to 25 model years old, and that weigh 18,000 lbs. or less.
What the Emissions Inspection Includes
Each emissions inspection confirms the presence and connection of the vehicle's required emissions control devices. This includes making sure that the vehicle's gas cap is present, is in good condition, and fits properly.
The emissions control devices are examined if the vehicle was originally manufactured with them. The vehicle model years affected are indicated below.
Catalytic converter (CAT) - all model years
Exhaust gas recirculation valve (EGR) - all model years
Positive crankcase ventilation system (PCV) - all model years
Air injection system (AIS) - 1984 and newer
Evaporative emissions control (EVAP) - 1984 and newer
Fuel inlet restrictor (FIR) - 1984 and newer
Thermostatic air cleaner (TAC) - 1984 and newer
You can help your vehicle pass an emissions inspection by keeping it properly maintained. If the vehicle's Malfunction Indicator Lamp (MIL, or "check engine" light) indicates there may be a malfunction or other problem, have the vehicle properly repaired. A well maintained, properly functioning vehicle uses less fuel and creates less exhaust emissions.
What Neil found says "Most vehicles with diesel engines are also exempt. However, diesel-powered vehicles that are registered at more than 8,500 lbs. and are registered in the New York Metropolitan Area (NYMA) counties of Nassau, Suffolk, Rockland, Westchester, or one of the five counties within New York City, are subject to annual emissions inspection. All diesel-powered vehicles over 8,500 lbs. maximum gross weight (MGW) operated in New York State, even if registered elsewhere, are subject to roadside inspections. These safety and equipment inspections are conducted randomly statewide by the New York State Police and the New York State Department of Transportation." This data was last updated on the Internet on 04/2011, so it's somewhat old.
If you're not in those areas (I am), your inspection guy might be misinformed.
My V10 is over 8500 lbs, not OBD-II compliant, and for the past two years hasn't had to get emissions inspected. Just safety. I wonder if these changes mean I will need to get a sniffer test done, like it was in the past. Not that I'm worried about it, it'll pass with flying colors
I suspect that since the diesels are all over 8500 lbs, they didn't come with OBD-II compliance in the first place, so this is all a dead issue.
swaybar
16
06-01-2009 06:18 AM
