5.4l camshaft issue
Old Sep 12, 2021 | 08:02 AM
Dr.BunnyFooFoo's Avatar
Dr.BunnyFooFoo
4wd Low
5.4l camshaft issue
hello and thank you for taking your time and reading this!
i am currently re-timing my truck as yes you know the phasers and other small things needed attention!
drivers side cam shaft rear lobe was badly worn due to failed roller follower (clicking noise like mad) passenger side is fine and peachy. So i got a replacement for drivers side cam but the issue i am having is there are two different part numbers on each cam also the notches on the cam guide are different.
bad camshaft # rf-5l1e-6c255-da
potential hopeful camshaft # rf-5l13-625i-da
Any help would be greatly appreciated!
thanks again for looking!
Old Sep 12, 2021 | 09:17 AM
redfishtd's Avatar
redfishtd
I wonder if the plant that made the engine may have slightly different versions . I am always shocked at the engine differences between plants . . I have pulled and reinstalled Both my cams during timing jobs. I replaced all rollers and followers and I slowly tightened and torqued them back down in sequence with rollers in place . But I'm not sure what the guides are. I do know the cams are different side to side. I do know all the parts have to go back exactly how and where they came out .. The cams must be different on the 08 heads ? They changed the sparkplugs on those .
I can't even visualize the cams now its been awhile .
I always wondered how you dealt with the cam journals if you had to replace cam . I know some places line bore the heads and put bearings in , to me that's a whole different world I haven't touched . .
Hopefully some one has a lot of experience with your question and will fill in a proper answer .
Ford tech malukoco would know .
Old Sep 12, 2021 | 10:18 AM
Dr.BunnyFooFoo
4wd Low
it's an 06, 07 in that range only months of difference.
the front of the cam just after the phasers the first cam holder( or whatever its called, the largest one on the cam right after the phaser) but on the cam the notches are different then the one i have,and that cam hold goes over it to hold it down, no idea if that makes a difference!
the part numbers are just not the same and the truck i pulled it from is and 07 like mine same drivers side but i would just like some clarity on it, i have googled it to death and only thing i have found is the cam i have to replace it with goes in a mustang 4.6l and the other (passenger cam) has the same model number as the stang.
is it weird or what!
Old Sep 12, 2021 | 04:54 PM
redfishtd's Avatar
redfishtd
07 was the change over year for heads , I think it was sometime in november 07 they went to 08 heads .. There has been running threads on just that , plugs/boots are different for one . you have to check the date code on the pillar .
Old Sep 15, 2021 | 08:19 PM
Dr.BunnyFooFoo
4wd Low
its 04/07 f150 5.4l
Old Sep 16, 2021 | 10:13 AM
redfishtd's Avatar
redfishtd
I haven't changed cams . There are some parts guys on here or you need to go to dealer and get numbers worked out. A auto machine shop who does heads might have an answer. Sorry . maybe they can shed light on journals/bearings . I would like to know in case I lose a cam .
I have heard the junk yards get stripped of the passenger cam because it gets worn out first .
Freedom racing
5L1Z-6250-E 5.4L 4.6L 3V Camshaft (Left) drivers side
5.4L 4.6L 3V Camshaft (Left) Driver Side 5L1Z-6250-E 5L1Z6250E
Replaces 5L1Z-6250-A 5L1Z-6250-AA 5L1Z-6250-B
I can't correlate to your numbers
I don't know if you can get a answer out of ford tech malukoco ,that guy knows it all .
rock auto 2004
ENGINETECH ES6250 {#3L3Z6250JA} Info
Left; Left Hand. Use with L5400 lifters.
Rockauto 2005 f150
SKP SKES1584 {#5L1Z6250AA} Info
Left
rock auto 2007
Left
Old Sep 16, 2021 | 08:48 PM
Dr.BunnyFooFoo
4wd Low
Thank you for your time,I will find one with those numbers
Old Sep 17, 2021 | 07:42 AM
redfishtd's Avatar
redfishtd
Let us know about your journey . It surely will impact others on here. I just wished I took more pictures when I removed cams .
joey390burnout
Oct 2, 2023 01:01 PM
Phantomtruck68
May 23, 2021 04:52 PM
ng19delta
15
Jan 1, 2017 04:51 PM
wmiller
Aug 21, 2009 04:51 PM
Jan 23, 2002 01:41 AM
