Turbocharging
Old Sep 7, 2021 | 08:17 PM
humphrey169's Avatar
humphrey169
Ill have to do some more research but I would like to see the compressor map for that turbo. I have a feeling that a 43mm will be a choke point for that engine. What size exhaust housing is on it?
Old Sep 7, 2021 | 08:21 PM
Doc. Dewey's Avatar
Doc. Dewey
If memory serves, its 2 inches exit port but im not sure. Id Id h to check next time im im back in the shop (I work 4 hrs away from home).
Old Sep 8, 2021 | 08:12 PM
Briansshop's Avatar
Briansshop
I ran 22psi boost on a stock factory built 351w bottom end with no issues. Somewhere between 8-900 HP.
Old Sep 8, 2021 | 08:52 PM
Doc. Dewey's Avatar
Doc. Dewey
Was that also on the stock EFI system?
Old Sep 8, 2021 | 09:12 PM
torq'ta 5 8's Avatar
torq'ta 5 8
lol...god no!
Old Sep 9, 2021 | 08:40 AM
Scndsin's Avatar
Scndsin
I had a link saved of a pass you made before you sold it & can't find it.
Old Sep 9, 2021 | 09:59 AM
Mudsport96's Avatar
Mudsport96
the stock system is going to need upgrading, no 2 ways about it. Hell the factory fuel pump wont even keep up.
I know you say 7 lbs. But you need to prepare for 14 or 20... or what ever that turbo can supply. For the simple reason of unplanned boost increases. Failure of a boost controller, stuck waste gate, etc...
I learned this all to well years ago when racing and had a wastegate failure that nuked a perfectly good engine that was tuned just fine for where it was being run. Many, many sub 9 high 8 second runs with zero issues. Then one pass the gate didnt open, and the only indication was needing to grab high gear sooner than normal. Not having the boost gauge in a "good" visual field was a bad idea i will admit that now.
The map sensor was only a 2 bar, and the tune was good for 20 psi because the car was gated for 14, no need for anything else right. Wrong so very, very wrong. Not sure what boost it actually made, because of the 2 bar, but the rate of rise was so steep i would wager mid 30s maybe more.
It did coast to a 8.54 @154 after losing power at 1/8 mile.
So yeah, always plan for more boost than you ever plan on running.
Old Sep 9, 2021 | 11:09 AM
Scndsin's Avatar
Scndsin
He'll tell you "no", cause nothing else was stock on that setup but the long-block.
Old Sep 9, 2021 | 11:33 AM
SFaulken's Avatar
SFaulken
The stock EFI systems on these trucks isn't much good for doing anything other than stock things. It's not designed to be particularly tunable. I can't see any combination of parts that you're going to combine with a turbo, on any EEC-IV engine, that is going to allow you to not go to a piggyback like the Quarterhorse, or a complete ECM replacement, like the PimpX, or Holley TerminatorX
diesel-fitter-bum01
Sep 8, 2010 11:20 AM
RangerPilot
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 27, 2006 02:31 PM
96 f250 sluggggg
Dec 12, 2005 11:52 AM
Franken-Truck
Mar 7, 2004 11:35 AM
scott9050
Aerostar
Jul 8, 2002 06:08 PM
