How screwed am I?
Using a grinder, sawzall, chisels and hammer, 4 hours later I get the pipes off. But, each bolt is still in the exhaust manifold. A couple are ground off flush, one is sawed off flush, and the last one broke off a half inch above the manifold flange. None will come out. Went and bought the hardest drill bits Home Depot carries. I drilled on one for 10 minutes and you can barely tell.
I don't think it will matter even if I drilled all the way through - the bolts are like part of the manifold now. Beating with a punch and hammer does nothing. It must be a Minnesota thing (where the bus came from) how rusted they are. Never seen anything like this down here.
No way I can take the manifolds off - those bolts look just as bad. What am I doing wrong? I'm thinking the engine has to be pulled just to get these four bolts out. I heated with a small propane torch for about 3-4 minutes - do I need a hotter torch? This is insane. Is my drill not going fast enough? Do I need to start with a tiny drill and work my way up? Geezus, that would take hours.
I'm so screwed. Turbo is a two hour job on Fseries.
Considering your situation, I would clean off the PB Blaster with some brake or carb cleaner, put some Naval Jelly on the two sides of the manifold ears overnight, and hope it can dissolve some of the rust jammed between the bolt shanks and manifold. If you hammer too hard on those manifold ears, they can break.
I must need a different drill bit. Watching YouTubes and guys are able to drill them. The bits I bought said Hard Metal on them, but they're not drilling like the guys I'm watching.
I gotta be doing something wrong with this drill - those YouTube guys are having no problem, and I've drilled out bolts before. I either have bad bits or I'm not applying enough force to the drill - it barely fits in the space. and can't get my hand behind it - or it's not going fast enough - it's cordless and I'm letting the batteries charge up.
Do you know what kind of bits would be best? IIRC, these were titanium.
Retail bits from Bosch or Dewalt are not as bad as others, and there are different grades of Cobalt. I've got some industrial-grade bits from commercial sources that are excellent and very expensive. I've got a Craftsman bit set from 40 years ago that still has mostly original bits (resharpened); they don't make them like they used to. But the description you mentioned sounds like it's the Milwaukee bit, which is better of them. You might want to look carefully at the tip and see if you have chipped it so that it won't cut well. Those bit tips only last during the factory sharpening with me. You might be going too fast.
As namnguye mentioned, the metal may be heat or aged hardened, work-hardened if they have stretched past yield buy a guy with excessive force. Or someone installed 12.9 bolts instead of 10.9 or maybe stainless. But it's perplexing as I never encountered having this much trouble drilling a broken bolt as you do. Your other problem is drift with a bolt that hard and especially hand drilling. The cast manifold will be softer than the broken bolt, especially yours, so the drill will pull into the softer metal if there is an edge breakout. An EDM machine would be the best course, but you will not pay for a guy to come out with a portable unit.
All of this is why I suggested a try at dissolving the rust around the bolt's shank. Unless ToolManRob has other suggestions.
Net result, the 1/8 bit is almost through the flange and out the other side (I cut the bolt head off over there), and a larger hole, prolly 80% of the bolt diameter, follows it about half way. Still, what's left won't budge using the hammer and punch. $^#&*%&#(
Also tried heating it up again - nothing. What are the chances I can burn the rest of the bolt out with the torch? I've been only heating the flange. avoiding as possible getting the bolt in direct flame.
Not sure where to find any better bits, and prolly can't until Tuesday anyway. So I'm going to try one of the cobalt bits from OReilly's next, forget the brand. If it's no better than the Milwaukee, I'll go back to those - prolly cheaper at HD.
Sorry, Jack, and never got the naval jelly, or the acetone Mark recommended. Been continuing to soak with PBB, for what it's worth. Just got focused on drilling. My drills don't have a trigger lock. %_#%_#&. If a new bit works as well as that last one, I should punch through the bottom side pretty quick. But, I get the feeling that's not going to free up the rest of the bolt. It really acts like one hunk of iron, not two pieces rusted together. I'll prolly have to, somehow, drill out the complete diameter.
You are not going to burn the bolt out; an EDM would do that. Earlier this year, on the bulldozer, I played with PBB, A/TF, and LqW. The LqW, despite it being an older in-service product worked best, took less torque after all were soaking for 3 days.
I'm guessing Mark as suggesting acetone to work with ATF; since it's not in the thread, I guess you guys are talking privately rather than on the board.
That Milwaukee bit was definitely worn out. The O'Reilly bit broke right through the last of the bolt depth, but then, it didn't make much progress on the next bolt. I was thinking that me grinding on the bolt head created the heat to "harden" the metal; but I didn't grind the next bolt I'm trying - I cut it off with the sawzall - and it seems just as hard to drill (with the OR bit), and just as stuck - punch and hammer do nothing.
I'm going to try once more with new Milwaukee bits. A small one to start on that next bolt, and a larger one to try to ream out the first one. If I can't ream the first one, not much left I can do except pull the manifolds. The chances of that being successful are slim to none, likely just more broken bolts.
Question: why can the sawzall cut the bolts but the drill can't drill them?
Crazy to junk a perfectly good bus over 4 lousy bolts, but I may have no choice. I expect a tech will charge me more to remove those bolts than I paid for the bus.
I can't get those bolts out. I'd have to either pull the manifolds with the high risk of breaking more bolts, or have it towed to a shop and pay them some huge money.
I only paid $2500 for the bus and I made most of that back carrying loads back to Tx from picking it up in Minn. I've put 20k revenue-generating miles on it since then. It was a free bus and has paid off great since then.
So, I'm going to take a chance. Talked to my gasser-tech buddy and he suggested burning the bolts out with the torch. I know Jack said that requires and EDM (what is an EDM?), and he's almost always right, but what the hell, I'll try.
Probably doesn't work, so Plan B is to just weld the pipes back together. Not quite sure if I can pull them tight enough together to seal up, but I'll try. Then just drive it until I need to take those pipes off again. Maybe I can just tack it so that I can grind the weld off to pull the pipes if I ever need to. If not, I'll just junk it.
If neither option works, I can junk it now and not feel bad.
The Life of Bonehead is not for the squeamish.
Try these, they're dirt cheap.
Make sure to keep it cool when drilling or it'll break off.
https://www.harborfreight.com/carbid...-pc-61617.html
