Speedo issues
Old Sep 3, 2021 | 05:23 AM
Tbanks1382's Avatar
Tbanks1382
Trailering
Speedo issues
Speedometer in my 1985 F250 hasn’t worked since I bought it. I unplugged the end out of the transmission and when spun in the chuck of my cordless drill the needle moves. The plastic gear on the end of the cable appears to be in good shape. Obviously there is an issue with it mating inside the transmission any ideas on a remedy?
Old Sep 3, 2021 | 05:53 AM
Franklin2's Avatar
Franklin2
What transmission? Or does it go in a transfer case? What kind of transfer case? Most but not all, you can pull the tailshaft housing off and get access to that drive gear.
Old Sep 3, 2021 | 06:30 AM
Tbanks1382's Avatar
Tbanks1382
Trailering
I’m not sure which transmission. It’s a 4 speed manual. The Speedo cable plugs into the back of the transmission itself.
Old Sep 3, 2021 | 10:38 AM
Franklin2's Avatar
Franklin2
Here's a old thread with some info on getting the gear. Since you have a f250, you could have the np435, or a t18 or t19 transmission.
https://www.ford-trucks.com/forums/7...rive-gear.html
Here's a link that might help in identifying what you have. If you have a 460 engine, you most certainly have a t19 but double check to make sure.
Old Sep 4, 2021 | 11:55 AM
FuzzFace2's Avatar
FuzzFace2
Just to let you know it dose not take much wear on either gear to cause issues.
I had a T18, granny first gear 4sp, that I had to replace both the cable end gear (driven gear) and the gear on the output shaft (drive gear) to get my speedo to work.
Because the T18 was bad a swapped in a NP435 using the same driven gear and it did not work.
In checking the drive gear it showed a little wear so I swapped it for the T18, yep both use the same drive gears, and it worked again.
So a little wear can cause issues.
Dave ----
Old Sep 9, 2021 | 10:00 PM
Station25's Avatar
Station25
Trailering
Inside tailshaft of trans is another plastic gear. Poke your finger inside of it. I'll bet you feel a worn down grove in the center of it...also try to spin it. Shouldn't move.
Krisandkatrina Garcia
General Automotive Discussion
Aug 24, 2020 09:19 AM
1968bumpside
Mar 16, 2012 12:36 PM
taylor0987
Feb 8, 2005 05:30 PM
hedgeapple
Aug 4, 2004 01:52 AM
Mithrandir
Jun 1, 2004 07:27 PM
