96 f250 7.3 Auto shifting problems
Old Aug 30, 2021 | 07:30 PM
tbart16's Avatar
tbart16
transmission wiped out had it rebuilt... transmission worked fine for a few hundred miles then It wouldn't shift into passing gear... I figured out that it was the LED brake light bulbs... Put a couple more hundred miles on now I sporadically lose 1st gear. Somedays it's fine other days it won't. Tranny fluid is clean. 3rd brake light is an LED. Any ideas appreciated.. thanks Tom
Old Aug 30, 2021 | 08:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My idea is to read the codes. WIthout the codes, all you can do is throw parts at it until you get lucky.
Old Aug 30, 2021 | 08:58 PM
wwhite's Avatar
wwhite
Smell the fluid, colour should be brilliant red, but is probably burnt and brown in colour, and you may have damaged the TC.
Have you removed the LEDs, and put regular bulbs in?
If you still have LEDs, did you put correct resistors installed with the lights?
Jeff Proctor
May 29, 2020 09:01 AM
alaskajim
Jun 4, 2018 11:53 AM
paintubturner
Apr 19, 2018 09:25 AM
pickncrew
Jan 11, 2010 06:24 PM
erik-the-viking
Aug 5, 2008 07:59 AM
