Miffed - 5/16" Tube Nut Doesn't "fit"
So after spending a few hours and a few failed attempts at bending a perfect (to me...) fuel line, I install the flare on the fuel pump end and lock in the standard flare nut. I thread the new line in and go to tighten up the tube nuts on the ends: the carburetor end tube nut threads in and bottoms out on the flare with a few threads of the nut to go - the line is nice and solid. But at the fuel pump end, the tube nut itself threads all the way in and the line is still loose in the fuel pump and can be pushed further in by over a 1/8". Said differently, the threaded hole in the fuel pump is much deeper than the tube nut and the flare of the line will not seal at the bottom of the hole.
The pump is an aftermarket Carter pump. The port in question is the top one:
As you can see, there is a smooth portion below the threads, that tells me that there is either another type of fitting that I should be using, or a different type of flare should have been made by me. I have done an intensive search and I don't think there is a longer tube nut fitting that will make it to the bottom of that port. Kicker is, the flare that I made is the same type of flare that originally came with the truck and fit in the original fuel pump.
Please give me a direction to go in, because this is frustrating. This engine reassembly should have been fun, but instead it's turning out to be a bit of a nightmare...Also please see my post regarding carburetor linkage...!
Geoff
Geoff
Geoff,
Just to restate.
Fuel Pump Inlet/Outlet is 1/4”NPT.
Your fuel line is 5/16”.
The adapter will go from 1/4” NPT to 1/2”-20 or 5/8” flare (has the little center flare)
Then you will use a flare nut for a 5/16” line that matches the 1/2”-20 or 5/8” thread of the adapter.
There isn’t a 1/4”NPT to 5/16” because the second number is the nut thread and the line would be smaller. If you already crimped on the nut, then try and find that size. Most times it’s tough because you used a 3/8” nut.
good luck.
Just to restate.
good luck.
Tim Hodgson
06-17-2019 05:42 AM
The_Scatch
05-22-2019 05:42 PM
seventhfire
1999 to 2016 Super Duty
08-31-2018 09:30 PM
