oil pump nut
Old Sep 1, 2016 | 10:00 PM
flipklos's Avatar
flipklos
oil pump nut
Does anyone have an oil pump nut or a part number to search for one?
I am in need of the nut that fits over the pickup tube and threads into a geroter style pump?
Mine is leaking due to the surface being turned down as I bunged up my threads some and am weary of the slow drip.
thanks,
flipklos
Old Sep 2, 2016 | 03:53 PM
charliemccraney's Avatar
charliemccraney
The nut itself is not sealed. The seal is achieved by the rubber grommet, which is compressed against the tube and pump housing. If the oil is actually dripping from that area, then there is a problem with your pickup tube or the pump housing.
Old Sep 2, 2016 | 05:46 PM
flipklos's Avatar
flipklos
My nut was shortened up in a lathe due to bad threads that would not hook. I tried shimming it out with bushings but it still leaks. Prior to dinging the threads it did not leak.
I did take it apart, clean it and stuff it with RTV once and reassemble it. I let it dry and it slowed the leak but am tired of the drips.
Hence why I want the nut,
Old Sep 2, 2016 | 06:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EAD-6673-A .. Nut-Oil Pump Screen Cover & Inlet Tube / Obsolete
AITKEN MOTOR CO. in Aitken MN has 7 = 218-927-2169.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 19 = 800-476-9653.
B4A-6698-A .. Seal-Oil Pump Inlet Tube / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 7 = 701-523-3257.
SOEBY MOTOR CO. in Walhalla ND has 11 = 701-549-3711.
AITKEN MOTOR CO. has 13.
GREEN SALES CO. has 216.
Old Sep 2, 2016 | 09:13 PM
flipklos's Avatar
flipklos
Thank you ND. I believe you have solved my problem,
fabieber
Nov 16, 2015 10:36 PM
Proamas
Sep 10, 2013 10:00 PM
jack odom
Aug 1, 2013 05:25 PM
Z06MAN
Aug 30, 2010 09:48 PM
yellow72f100
Feb 20, 2006 07:59 AM
