Two questions. Do you want a winch? Do you want it hanging off the front of your truck or hidden?
Answers. 1. Yes 2. Hidden
Only three options as I could see it. 1. Buy the Tremor Warn winch. 2. Do like Colin and design and build your own. 3. Buy Colin's set up.
I decided to go with option 3. It arrives in four packages. Now I need to get to welding once the fourth package arrives.
following your progress
favor. Can you draw a trap for depth on your truck
from the front most collet to the inside lip edge of the bumper
thanks
ZooDad
I finally welded and installed the kit. Not too bad. I'm going to put the winch relay in a different box. The one that came with the winch is ridiculously big with a ton of empty space. I'm also going to try to find a spot under the hood to mount it, but space is at a serious premium...
