Cruise control stopped working
Old Aug 24, 2021 | 03:13 AM
redbug's Avatar
redbug
Hello,
2001 f250 4x4 cc automatic 7.3
My cruise stopped working.
i see on some old posts that there was a recall, would ford still honor that in 2021 20 years later?
Where should I start looking for the problem?
Thanks,
redbug
Old Aug 24, 2021 | 04:32 AM
FordTruckNoob's Avatar
FordTruckNoob
The Tech Folder has the diagnostic procedure. Linked here for your convenience.
Old Aug 24, 2021 | 04:50 AM
AuF250's Avatar
AuF250
Most probably the cruise control cut off switch on the master cylinder which is what the recall related to.
if you order a new one it comes with a new fusible link as well as the switch. No need to drain the master cylinder to replace as very little drips out.
Quick way to check if it is that, unplug it and jam a mini blade fuse in the end of the lead. See if it works as usual. If it does, replace the switch. It's a secondary safety feature and there as a back up to disable cruise if the brake switch goes south.
Old Aug 24, 2021 | 07:15 AM
SkySkiJason's Avatar
SkySkiJason
Check 3rd brake light bulb first. Use incandescent bulb.
Old Jul 16, 2022 | 03:58 AM
redbug's Avatar
redbug
Replaced master cylinder sensor and switches in steering wheel. Cruise still not working. No cruise related lights on dash. Tried test procedure to get dash lights to spit out error code but that did not work. All fuses look good. Now what?
Old Jul 16, 2022 | 06:57 AM
SkySkiJason
After doing this, you’ll need a scan tool. Many of us use FORscan Lite ($6 app) and a BAFX OBD2 BT dongle ($20). This does almost everything the dealer scan tool can do.
Old Jul 16, 2022 | 08:02 AM
udsuth78's Avatar
udsuth78
Have you inspected the wiring for the VSS in the rear differential yet? Second question, does your horn work? If not then clock spring is suspect.
Old Jul 16, 2022 | 08:45 AM
Kwikkordead's Avatar
Kwikkordead
I second this. My VSS went out and the only indication that I had was the speedometer quit and so did the CC. 1999 F550 ZF6 stick shift.
Old Jul 16, 2022 | 09:09 AM
Supercab's Avatar
Supercab
On MY L99 if I don't drive it for a month or more the cruise won't work at first - The first time it did this so I just kept pushing the buttons and it came on just fine.....may be the case here as well??
I'm thinking the contacts inside the switch may get "dirty" from non-use..
Old Jul 16, 2022 | 11:28 AM
SkySkiJason
There are probably a dozen reasons the cruise control may not work.
A $1 bulb is one of the most common and the cheapest and easiest reason. After that, you need a scan tool or just keep throwing parts at it.
Old Jul 16, 2022 | 11:59 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If parts throwing is not on your schedule of events, look closely at post #2, which I have quoted below. This is the method any competent shop that charges $100 per hour or more or Ford would resolve the issue.
Good luck and keep us updated.
EDIT: A bit more aid is below.
Link: https://www.ford-trucks.com/forums/1619109-not-your-average-dome-light-or-cruise.html#post19207517
Old Jul 16, 2022 | 01:37 PM
Kwikkordead
If that circuit is open, it disables the cruise?
Old Jul 16, 2022 | 02:21 PM
FordTruckNoob
It also opens up a wormhole to Bizarro World.
Old Jul 16, 2022 | 02:45 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
No. Not even on a 95-97.
The PCM needs to see a ground (not open circuit) on the brake on/off (BOO) input for cruise to be enabled and 12v when the pedal is depressed. On a 99-up, that ground is supplied through the brake light switch and a dedicated ground - not any light filaments. The brake pressure applied (BPA) input needs to see 12v from the fire-starter switch on the master cylinder to enable cruise control and an open circuit with the brake depressed to cancel.
These two inputs are visible in ForScan and with a factory tool. If both of these are good, the inputs from the switches need to be verified. Again, ForScan has them I think....but I know for sure the Ford tool does.
For clarification sake, the 95-97 trucks get the BOO ground signal to the PCM through the brake light filaments (not JUST the center high mounted stop light - CHMSL). This is why LEDs often cause issues with them.
Old Jul 17, 2022 | 01:30 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Series of pictures of what ForScan Lite should show for cruise data:
At rest
Off button pressed
On button pressed
Resume button pressed
Set button pressed
Coast button pressed
If either brake (or parking brake applied input not pictured) says "on" when your foot is not on the brake, find that problem first.
