Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700 Decode
Old Aug 20, 2021 | 04:57 PM
cwolff's Avatar
cwolff
F700 Decode
Hello and thank you for this valuable service. I have a potential project I'm looking at and humbly appreciate any info that can be provided.
Best regards,
CJ
Old Aug 20, 2021 | 11:59 PM
85e150's Avatar
85e150
F70 = F700 gas
F = 391 4V XD FT gas (lots of it) V8. "XD" took the place of "HD" in most cases.
V = Kentucky Truck Plant
Y91116 = 1977 series number
212 = 212 inch wheelbase
KC
K = Bright Red
C = Special White
F709 = This shows as a 1978 model code for F700 with 27.500lbs GVWR Note series numbers are mid to late '77 model year. I have no insight into such discrepancies.
16 = My source does not pair a "1" with a "6". The "6" refers to "Fire Truck Standard Cab" in the listings, but paired with a letter. Since this is a special order truck, perhaps they did things differently but afaik that is usually not the case.
7 = Spicer model CM-5052A five speed direct transmission
HQN =
HQ = Eaton model 17121 single speed rear axle, 18,500lb capacity, 7.17 ratio
N = Ford 9,000lb capacity front axle with power steering
27500 = 27,500lbs GVWR
260749
26 = New Orleans District Code
0749 = Special Order Number
If anything doesn't match up, let me know. Some of this, like the axle code and special district code, are hard to read.
27.500 GVWR gives you CDL to deal with unless you will be exempt under one of your state's exemption policies.
Old Aug 21, 2021 | 12:02 AM
85e150's Avatar
85e150
Post moved to it's own thread. Good luck with it!
cousinscustoms
Large Truck
Jul 1, 2021 11:28 PM
tanman722001
Large Truck
Jun 29, 2021 04:58 PM
Jamie Miles
Large Truck
May 25, 2021 03:43 AM
Joshua Ade Richards
Large Truck
May 6, 2021 11:39 PM
Bigpiney
Large Truck
Mar 3, 2021 02:02 PM
