Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 decode
Old May 1, 2021 | 12:24 PM
Jamie Miles's Avatar
Jamie Miles
F600 decode
Hi, looking for a decode on this tag? Truck showed up in a local scrap yard. I'm looking for parts for my 71 which has a 330 2V M.D. engine and clark 285. I'm wondering if the 4V intake/carb and trans from this truck will fit my 71?
Thanks.
Old May 1, 2021 | 08:52 PM
85e150's Avatar
85e150
I can decode it late Tuesday or Wednesday. Look at the intake next to the carb on both sides. There should be a small runner on each side. Both manifolds should have that. That indicates a FT manifold. If they both have that, they interchange. 80 pounds plus so use a crane if you can.
Old May 4, 2021 | 08:11 PM
85e150's Avatar
85e150
F61 = F600 gas 4x2
E = 361 4V OR 2V XD FT gas V8. ("XD" in place the previous "HD") ('76 used the same code for 2V and 4V)
V = Kentucky Truck Plant
C52854 = 1976 series number
194 = 194 inch wheelbase
No color code, note special order
F612 = F600 gas 21.000 GVWR, 4x2
GA8 = Regular cab, standard. I do not have the upholstery or seat type info.
M = Clark model 285V five speed direct transmission
53L
53 = Rockwell (Timken) model H-170, 17,500lbs capacity, single speed rear axle, 6.14 ratio
L = Ford 6,000lbs capacity front axle
21000 = 21,000lbs GVWR
228031
22 = Charlotte District Code
8031 = Special Order Code
Old May 5, 2021 | 12:45 AM
Jamie Miles
Thanks for the info! Has the same trans and rear axle as my 71!
Old May 25, 2021 | 03:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
BODY GA8: GA = Black all Vinyl with Black Appointments // 8 = 81A Standard Cab with full width seat.
i61164
Jul 14, 2020 08:45 AM
Cliffy carlock
Jul 21, 2019 03:15 PM
driveguy
Apr 20, 2017 09:15 PM
BarePaw
Apr 28, 2015 03:15 PM
a11budman
North Carolina Chapter
Sep 10, 2006 01:58 PM
