Heat and Defrost problem
Old Nov 1, 2003 | 12:53 PM
JARHEAD8387's Avatar
JARHEAD8387
I have a 1987 F-150 XLT, the last time i needed help you guys came through ( my fuel situation is resolved). Now I am noticing the smell of anti-freeze in the cab, and when i turn on my heat or defrost, steam or smoke is pouring out of the vents, is this a common problem with older trucks, and is it something i can fix myself without too much trouble.
John
Old Nov 1, 2003 | 01:22 PM
Steven@nd's Avatar
Steven@nd
Easy fix, should be able to do it yourself. You need a new heater core, I would guess cost to be anywhere from $20 to $45 depending on where you get one.
Don't know the exact procedure, but it shouldn't be too hard. Basically, the heater core is behind the glove box, there should be some screws holding a plastic cover on, then what looks like a radiator inside it, take off heater hoses under the hood and it should come out from the inside.
I'm sure someone will chime in with better instructions...
Old Nov 1, 2003 | 09:11 PM
Steven@nd's Avatar
Steven@nd
Here's a little better help on changing that heater core:
1. Disconnect negative battery cable (don't have to, but always recommended when working on vehicle)
2. Drain coolant. (don't have to, but makes less of a mess under the hood)
3. Disconnect heater hoses from heater core on engine side of firewall.
4. Remove glovebox for easier access.
5. Remove 7 screws that attach heater core cover to the plenum assembly.
6. Disconnect vacuum source, but leave harness attached to cover - remove cover.
7. Remove heater core.
Install is reverse of removal. Be sure to put the rubber/foam spacer on the new heater core to seal it against the firewall.
Here is a pic to help you out too: http://members.tccoa.com/smgussey/fr...heatercore.jpg
Hope this helps!
Old Nov 2, 2003 | 05:06 AM
marragtop's Avatar
marragtop
Before you replace the core, make sure the lines going into the core aren't leaking at the firewall. Could just be a loose clamp or bad hose.
John McCord
Nov 18, 2013 10:23 AM
wanabe2
Dec 7, 2012 05:06 AM
JOHN2001
85
Apr 9, 2011 09:43 PM
pastorattheridge
15
Sep 21, 2007 08:05 AM
dlssboyce1
Dec 6, 2006 04:30 PM
