2003 Expedition Blend Door
Old Nov 11, 2013 | 09:16 AM
John McCord's Avatar
John McCord
I have a 2003 expedition and have no heat coming out of my defrost or front vents. When I turn on the vents in the back I have heat but no heat up front. It blows air but no heat. I don't hear any clicking or any door open or close. What do I do first. I think I use to hear a door close or open. What do I do?
Old Nov 17, 2013 | 09:11 AM
bb288279's Avatar
bb288279
Check the vacuum lines under the hood next to the fire wall on the passenger side. I had one leaking and the vents under the dash would not function. I believe the blend door is part of this same system. you can crawl under the dash and work the diaphragms manually to see if that works.
Old Nov 17, 2013 | 09:25 AM
alloro's Avatar
alloro
...behind the battery.
Old Nov 17, 2013 | 11:16 AM
projectSHO89's Avatar
projectSHO89
The blend door is not part of the vacuum-controlled system, it is an electrical motor assembly.
This is NOT a vacuum problem, check the blend door operation.
Old Nov 17, 2013 | 03:14 PM
pdqford's Avatar
pdqford
I believe he is having problems with the MODE door. Isn't that still controlled by vacuum in 2003?
Old Nov 17, 2013 | 04:26 PM
projectSHO89
His description is not of an incorrect airflow problem. He specifically said "No heat" so I'm taking it at his description. "No heat" is never a vacuum problem.
Vacuum problems show up as issues where the air inlet/outlet is incorrect.
Old Nov 18, 2013 | 10:23 AM
alloro's Avatar
alloro
In re-reading the first post I guess it can be taken either way.
smsperformance
Apr 4, 2015 10:30 PM
evenwill
Mar 30, 2015 11:46 AM
paradiddle
Dec 9, 2004 06:43 PM
memphisfordguy
Aerostar
Mar 3, 2004 05:40 PM
kinglg
Jun 14, 2003 01:17 PM
