Won’t shift when warm.
Old Aug 17, 2021 | 06:17 PM
Donny Robinson's Avatar
Donny Robinson
2/97 f250 5,8 l auto. Shifts great when cold but after warm up you have to lift on gas to get it to shift 1to2 is really bad 2 to 3 is sometimes bad.. I thought it was a vacuum problem but this trans does not have a modulator.. is this a worn valve body? 255,000 miles update.. changed the vss .. did not solve the problem.. when pulling codes I got a 65 then code reader stops and now doesn’t initiate tests..
Old Aug 17, 2021 | 07:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored in the PCM?
Old Aug 17, 2021 | 08:15 PM
Donny Robinson
No codes
no codes available
Old Aug 18, 2021 | 05:43 AM
ABR3's Avatar
ABR3
I don't know about the 97,if Mark is on here he can answer better...but my 94 5.8 E4OD was doing the exact same thing...it was the speed sensor on the rear differential...got a two wire clip and one bolt holds it on. Changed it and it had a little difficulty the first time I drove it after swapping but none since.
Old Aug 18, 2021 | 05:45 AM
ABR3's Avatar
ABR3
Old Aug 18, 2021 | 04:01 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by ABR3
oe sensors are notoriously reliable and the aftermarket.. eh.. I would test it first… and verify wiring is okay before replacing it.
Old Aug 18, 2021 | 05:09 PM
ABR3's Avatar
ABR3
Yep... I agree... I actually broke a clip on mine trying to change it so I had to swap the plug too
rapidroy5858
Jun 25, 2012 09:53 PM
graymule
Nov 4, 2010 08:53 PM
clgreer
Oct 14, 2007 02:07 PM
mealan
Bronco II
Jan 12, 2004 09:24 AM
1967fordranger
Jan 24, 2002 10:43 PM
