Bronco II Ford Bronco II
Auto Not Shifting??
Old Jan 4, 2004 | 04:30 PM
mealan's Avatar
mealan
Auto Not Shifting??
hey guess, i got the a 88 bronco with electric 4x4 and here is my problem.
It seems that when driving the auto trans is in gear, it likes to stay in gear, and it wont shift until much higher RPM's. I am a pretty decent around cars so im not scared to go tearing into stuff. Any ideas? It does this all the time, hot cold, everytime, keeping the trans in 1st then shifting it into 2nd via the auto shifter still doesnt help it that much, how is the tranny controlled and told when to shift? - when it does shift, it shifts fine, its just way to high in the rpm band - around 5k. So once again, any ideas? Thanks guys!
Alan
forgot to add this is only on the 1-2 shift , the 2-3 and 3-4 are great!
Old Jan 4, 2004 | 10:35 PM
mrshorty's Avatar
mrshorty
1-2 and 2-3 shifts are controlled by engine vacuum/RPM via the vacuum modulator. One quick check of the vacuum modulator involves simply checking the vacuum line from the transmission to the intake manifold for ATF.
3-4 and TCC lockup are electronically by the PCM via two electrical solenoids in the valve body.
Old Jan 4, 2004 | 11:06 PM
mealan's Avatar
mealan
oh, the trans was just rebuilt, and the 2-3 shift's fine, checked that and no ATF fluid, however, i saw a post on all data about a delayed 1-2 up shift being caused by not putting a spring back into a governor, any idea with this governor, I'd certainly like to find it, here is a picture, thanks!!
alan
Old Jan 7, 2004 | 11:26 AM
MJB's Avatar
MJB
Is reverse OK?
Old Jan 7, 2004 | 04:58 PM
mealan's Avatar
mealan
yep, reverse is good.
Old Jan 7, 2004 | 06:31 PM
Bronco 1169's Avatar
Bronco 1169
Well you heared of Sea Foam or Deep Creep? well that have a trans stuff it help's may fix it ?
Old Jan 7, 2004 | 06:34 PM
MJB's Avatar
MJB
Reverse is OK, Vacuum modulator is OK then govenor could be the problem. Take it back to whomever rebuilt it and tell them to do it right this time.
Old Jan 7, 2004 | 06:37 PM
Bronco 1169
The exshust might be stoped up?I got a auto trans that don't have reverse in a Bronco 11.
Old Jan 7, 2004 | 08:03 PM
mealan's Avatar
mealan
cant, they went out of business lol i would glady have done that though!
Old Jan 11, 2004 | 03:17 PM
mealan's Avatar
mealan
anyone? or maybe i should ask in the trans section??
thanks guys!
alan
Old Jan 12, 2004 | 09:24 AM
Ken00's Avatar
Ken00
Give our tranny forum a try if you don't get anythjing more here.
