E4OD Trans Mount Play
Old Aug 17, 2021 | 08:56 PM
e30rik's Avatar
e30rik
Originally Posted by Mark Kovalsky
I recommend getting Forscan. Then you can read the codes and know why the lights came on. Without the codes, all one can do is guess.
Wasn't aware there was anything like that for these trucks. After a quick Google search it looks like it's for OBD2 systems, unless there's an adapter or something. I have the OBD1 scan tool, I got the all clear with it when I tested a few days ago.
Old Aug 18, 2021 | 10:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Did you plug it into the ABS system or the powertrain system? The PCM isn't going to give you ABS codes.
Old Aug 18, 2021 | 10:36 AM
AuroraGirl's Avatar
AuroraGirl
since you bring up the concept, how many different systems would these trucks have that are separate and does SRS have one or does the flashing light corresponds to a code the only interface one can have
Old Aug 18, 2021 | 11:49 AM
Mark Kovalsky
SRS has one, too. It has been too many years for me to come up with all of the systems that can have codes stored. Later model vehicles have everything accessible through the OBDII port. These trucks do not.
OldBlack4x4
Jan 9, 2015 04:43 PM
rsdjcarter
May 3, 2009 08:16 AM
relentlessmx
Dec 20, 2008 02:14 PM
mike b
Feb 9, 2003 03:20 PM
